In Search Of An Odd Outlet Face Plate. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 04:41 PM   #1
In search of an odd outlet face plate.
I was looking for a way to hard wire a wall mounted hair dryer to an outlet and keep at least one of the plugs available. Is there an outlet face plate with a small hole to run a wire through maybe even in place of one of the plugs?
I am the Asst. Manager at a hotel and we have to keep up with fire code as well so i require one that is designed around a surge protected outlet.
Help would be greatly appreciated.
apheix is offline   Reply With Quote
Old 05-12-2013, 05:08 PM   #2
funfool's Avatar
Rewards Points: 534
Just wow is all I got.
funfool is offline   Reply With Quote
Old 05-12-2013, 05:10 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,964
Do like the rest. If the customer likes it so much, you add the cost of the item to their bill should it come up missing.
Old 05-12-2013, 05:42 PM   #4
joed's Avatar
Rewards Points: 13,322
Fish the cable in the wall to a junction box behind the dryer.
Old 05-12-2013, 06:51 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Simple, hire an electrician, he will have all your answers.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
frenchelectrican (05-12-2013), k_buz (05-12-2013), user1007 (05-12-2013)
Old 05-12-2013, 09:02 PM   #6
Maybe I have not been clear. I have a box of hair dryers that need to replace old ones in rooms but the ones I have are not plug in they have loose wires. The entire hotel has hair dryers in the rooms. I can't send back the ones I have because we have had them since who knows when.
Old 05-12-2013, 09:03 PM   #7
E2 Electrician
And there is no way in hell you can install those without an electrical contractor.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 05-12-2013, 09:04 PM   #8
Trying to save on the money. It would be best to figure out something on my own or with some internet help.
Old 05-12-2013, 09:06 PM   #9
E2 Electrician
Do you know the outcome if someone is killed? It will not be pretty. You can kill yourself doing work in your own home doing your own wiring, but you can't do this type of work outside of that.
Old 05-12-2013, 09:06 PM   #10
Yes there is a way to do it. If one man can do it so can another.
Old 05-12-2013, 09:06 PM   #11
E2 Electrician
good luck.
Old 05-12-2013, 09:08 PM   #12
Right, because killing the breaker is out of the question. You're not helping.
Old 05-12-2013, 09:16 PM   #13
" Euro " electrician
frenchelectrican's Avatar
Well sorry to be harsh but you mention motel ., any electrical work have to be done by electrician and I will not let any " handyperson " get into electrical system that something you don't want to mess around.
There are specfic rules we have to follow to install those items. You just can't " half a$$ed " rig them up.
Now next part you say killing the breaker is out of the question that is wrong right there you can shedule a short down time to shut a branch circuit breaker to that room and deal with it and OSHA will love to heard this one.
And I am sure you undestand this is a DIY fourm genrally geared to the homeowners not the commercal owner whom try to save money if not following the regulations or codes.
Again sorry to be harsh but the codes are strict on them espcally with motels.
I live in France and we do have very strict codes to follow it the same way with Americian electricians to do it.
So bottom line it much better just hire a electrician and go from there.
Bon Chance !!
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
apheix (05-12-2013), user1007 (05-12-2013)
Old 05-12-2013, 09:20 PM   #14
Too Short? Cut it Again!
Not sure I understand the post but here is a company that just sell switchplates. And where are you by the way? You might want to update your profile with basic information.
http://www.justswitchplates.com/swit...ize=1+Cable+TV
You can get a plug that goes in a standard socket coverplate that has a round hole for a cable tv pass through or fitting and a blank in the other side that plugs it.
I don't think you can get away with hot wiring hairdryer inside the wall though. You should bite the bullet and call a sparky. If something goes wrong, you will be up a creek without a paddle. Of course what could possibly go wrong with electricity near water and a cord to a heat element buried in the wall without protection?
I think the point people were trying to make is that you most probably need a licensed electrician sign-off on this project---just for insurance purposes or for inspections---so in that sense you cannot do this work yourself unless you are licensed.
Again, I admit I do not fully understand what you are trying to do but why not just wire plugs on the end of these if they have none? Then just plug them into protected outlets in the conventional way?
The Following User Says Thank You to user1007 For This Useful Post:
apheix (05-12-2013)
Old 05-12-2013, 09:56 PM   #15
jproffer's Avatar
Rewards Points: 716
So you're going to leave the breaker off forever?
He's not talking about killing someone who's doing the work, he's talking about fire and electrocution hazard after it's done wrong and some unsuspecting guest gets fried, one way or another, because YOU couldn't afford an electrician. I hope you can afford a lawyer.
jproffer is online now   Reply With Quote
Tags
hard wire , outlet , outlet cover , plug , wall plate
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 06:37 AM
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 07:07 AM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Router Mortising Kit for Door Face Plate GeauxCajuns82 Carpentry 9 02-15-2011 11:08 PM
Getting shocked by face plate screws vogtage83 Electrical 21 12-04-2007 11:55 AM
