Sealtite Not Plastic Underground? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 09:02 AM   #1
walt1122
Rewards Points: 334
sealtite not plastic underground?
Hi all, Can I use sealtite instead of plastic conduit underground to feed a septic grey water pump 20A about 30 feet from the house to the septic tank. Builder used plastic down the wall then ran outside UV wire outside of the conduit to the pump station put it back in plastic up the column to the box so it looked like it was in plastic the whole way. They he only burried the unprotected wire 4 inches down. Where he did put the wire in plastic he used umteen elbows ( least 5 90's to follow the contour of the house and footings. Suffice to say I have fix this and it would be a whole lot easer to run if I could use something more flexable.
thanks
Walt
walt1122 is offline   Reply With Quote
Old 04-12-2011, 09:11 AM   #2
Rewards Points: 330
if seal-tite is rated for direct bury okneeds to be at least 18" deep.24 is better.sch 40 grey pvc house to pump.
oleguy74 is offline   Reply With Quote
Old 04-12-2011, 10:19 AM   #3
walt1122
Rewards Points: 334
Hi oleguy74, I get
if seal-tite is rated for direct bury ok.
24 is better
but what does "sch 40 grey pvc house to pump" mean?
I was asking if I could run sealtite INSTEAD of sch 40 grey pvc house to pump.
I figred I needed to have it at the 18" depth but all the bends in the sch 40 grey pvc house to pump would be easier if I could use sealtite. There is sandstone at about 6-7 inches so I know I have some jackhammering to do and that is why he didn't do it. To lazy!
But let me ask if there is ANYTHING that I can use so I don't have to hammer out the rock.
thanks
Walt
Old 04-12-2011, 10:50 AM   #4
Rewards Points: 168
While sealtight can be buried, it is a waste of materials and also looks like crap. Run PVC conduit from the source to the pump. Here you can transition to sealtight for the motor connection.
PVC only needs to be down 18".
Old 04-12-2011, 11:45 AM   #5
walt1122
Rewards Points: 334
Hi J.V., I agree about the crappy look but I have 360 degree worth of bends. Isn't there something in the code talking about the number of bends/degrees, 360 or less or less than 360 degree worth of bends? Three 90's to get past the block over the footings and then out towards the pump where I need another one to go up to the control box. Thought it would be easier to just run the sealtite.
thanks
Walt
Old 04-12-2011, 04:10 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, you are limited to 360 of bends between pull points. That is for a rigid type of conduit or flexible.
The Following User Says Thank You to nap For This Useful Post:
walt1122 (04-12-2011)
Old 04-14-2011, 03:39 AM   #7
Plastic Ducting has now become by far the most commonly used way of protecting pipes and cables that are laid underground, both in domestic houses and gardens and in commercial installations such as under roads or playing fields. Whilst clay ducts are still often used in certain larger commercial projects, it is equally likely that larger bore plastic pipes will be found in today's construction sites. Providing ducting is laid correctly, it offers a number of benefits to an underground installation. Ducting primarily gives protection to the cable or pipe within from ground movement and animal activity, but it also alerts any future installation to the presence of a pipe or cable, often preventing costly damage and remedial works. It also makes it far easier to replace existing cables, or even add more, without the need for large excavation works.
aryanaa is offline   Reply With Quote
The Following User Says Thank You to aryanaa For This Useful Post:
walt1122 (04-14-2011)
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Can you snake plastic pipes? rosemonster Plumbing 10 01-17-2011 07:09 AM
Chrome paint on plastic Thurman Painting 3 08-24-2010 12:17 PM
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 04:43 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
