Old 06-18-2008, 04:27 PM   #1
newer than a newbie...
sealing a masonry hole for a wire
Hi All.
I basically have a large antenna for my house and when we moved in the wire only went to one side of the house (bedroom TV). I wanted to split this and have it go to the living room TV as well. So, I split the signal with a standard splitter and drilled a hole into the masonry in the basement and got the cable wire through. The problem is that the hole is a bit wider than the wire and I could see critters and of course cold air coming in in the winter time.
I'm not a 'cable guy', but what is the right caulking to apply on the outside, and also, should I use the expanding foam to spray inside where the cable runs through the drilled hole? I don't expect to move this ever, so I don't mind if it's mumified. But I do want to keep my basement/home free of cold and critters.
Thanks!
mcvane is offline   Reply With Quote
Old 06-18-2008, 04:51 PM   #2
Moderator
Termite's Avatar
As long as this hole is not below grade, a good quality latex or silicone exterior painters caulk will do the job. Something that is paintable and remains flexible would be a good idea.
Squirting foam inside the annulus of the hole wouldn't hurt either. Just remember that the foam will expand like crazy as it dries.
Old 06-18-2008, 10:18 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Silicone colored the same as the morter would be the best way to go. They actually make a pass through tube for walls where Coax goes throug, so that you do not have to seal the opening.
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Sealing above steel lintel in masonry building? mkchicago Building & Construction 1 02-28-2007 08:23 PM
How do I drill the hole in the wall if I don't know location of electrical wire popkadurak Remodeling 10 06-16-2006 11:06 AM
