#1 |
Sealing Conduit
How would I seal the top of the pvc conduit so no water gets in. It is 1/2" and has speaker wire coming out of the top for a speaker on a 2x4.
The conduit faces straight up. What would I use? It is standard 14ga speaker wire if that even makes a difference. Links are helpful. Thanks
#2 |
Electrical Contractor
Sealing Conduit
Glue an outdoor box on top and put something like this on the front,
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. |
#3 |
Electrician
Sealing Conduit
Being just speaker wire, I'd seal it with silicone or duct seal, if you don't mind the look. Does the bottom of the conduit go into the house?
Kyle Just because you can, doesn't always mean you should |
#4 |
Sealing Conduit
I would put a couple of ninety's on to form a U. Then, still seal it with silicone or duct seal to keep insects out
#5 |
Sealing Conduit
That would put the opening of the conduit about a foot away from where the speaker is. I would install a proper outlet box with plate to keep the water from getting in and stuff the box full of insulation so nothing will go in there.
#6 |
Sealing Conduit
The box seems like a good idea. I think I would just put a cap on it, drill the cap or the pipe from the side and silicone the wire in place......but that's just me.......
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Missouri Bound For This Useful Post: | rrolleston (03-03-2012) |
#7 |
Sealing Conduit
That would work too and keep stuff from getting in the pipe.
#8 | ||
Sealing ConduitQuote:
Thanks all! |
#9 |
Sealing Conduit |
#10 |
A "Handy Husband"
Sealing Conduit
Buried conduit will get wet no matter how you seal it. I hope your wire is rated for wet location.
#11 | |
And like rjniles said the wire should be rated for wet loacations and should probably also be sunlight resistant unless you plan on replacing it often.
#12 | |
I'm using the same wire I used 10 years ago outside. Its basic clear speaker wire for indoor use. It held up being directly buried for 10+ yrs. until an animal chewed on it. Same stuff I'm using in the conduit I just buried last week. The conduit is just going to keep animals from chewing on it, and keep it out of the sun/weather. |
#13 |
Sealing Conduit
Would this also work too? "Duct Seal"
It seems this is what electricians use, and I also so this at the top of a utility pole with the wires coming out of conduit. It just seems to me a big PVC box would be "ugly" and annoying up on the top of the post near the speaker. At least I can paint this stuff and have it not "stick out" like a sore thumb. http://www.homedepot.com/h_d1/N-5yc1...1&keyword=duct seal&storeId=10051 |
#14 | |
#15 |
Floor Sweeper
Sealing Conduit
how about gluing on a service head? The ones for 1/2 and 3/4 PVC aren't that big.
| Tags |
conduit, seal, speaker, wire, wood ![]() |
| Display Modes | |
| What conduit should I use? | mulltron | Electrical | 6 | 07-12-2011 02:34 AM |
| Sealing an underground conduit for future use | Bob_T | Electrical | 7 | 05-31-2011 11:01 AM |
| Warm and Noisy Electrical Conduit | Intravartolo | Electrical | 4 | 07-26-2010 02:46 AM |
| Chicago Conduit Rules | Wrigleyville | Electrical | 6 | 01-28-2010 07:49 PM |
| Sealing conduit coming into house encased with waterline | pacamaroman | Plumbing | 3 | 06-18-2009 09:48 AM |
