Seal Tight Use - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 03:59 AM   #1
seal tight use
how far can you run sealtight
johnp11 is offline   Reply With Quote
Old 08-16-2011, 01:39 PM   #2
Rewards Points: 204
There is no distance requirement as many people believe. I always use an EGC with sealtight. Check NEC article 350 for specifics.
Old 08-16-2011, 02:27 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
How long of a piece can you get?
Old 08-16-2011, 03:30 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
The lenght limit usually applies to comercial uses.....as in how from say a motor to the conduit. The typical seems to be 3' or less. A lot has to do with what they call the 'unsupported' length.
Old 08-17-2011, 10:43 AM   #5
Licensed electrician
Rewards Points: 1,788
One of the few limits concerns hot tubs.
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 11:58 AM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 10:56 AM
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 09:22 PM
How tight is too tight for a new basement wall? vseven Building & Construction 16 01-07-2010 08:50 PM
