SE Cable Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 10:35 PM   #1
I ask the impossible!
Rewards Points: 640
SE cable question
K, asked this before but didn't get an answer. When I went to buy cable at an electrical supply store, I asked for 4/0 aluminum individual conductors. This is for the run from the service drop to the meter. I already have 2" rigid galvanized conduit. For a 200 amp service.
So the guy said I should get SE type R instead. I went with it. So I have a cable with 4 conductors and I need 3.
Do I just run 2 hots and a neutral through the weatherhead and cut off the excess length of ground and leave it inside the conduit on both ends?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 05-03-2011, 06:53 AM   #2
Lic Elect/Inspector/CPO
SE cable question
I have no idea why someone at an electrical supply store would say ser is needed for service entrance.
You can do what have stated.
NJMarine is offline   Reply With Quote
Old 05-03-2011, 02:28 PM   #3
Rewards Points: 512
I'd take it back and make them give you SE type U. Be extra careful that you get enough cable (measure correctly) so that when you twist the bare stranded neutral wire you won't lose any of its length.
Low volt question (RG-6 cable & shorts) Alan Electrical 11 03-24-2011 12:56 AM
Underground Cable Question Livewire78 Electrical 7 12-09-2009 01:15 PM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 09:33 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
