SE Cable Next To Coaxial Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 09:57 PM   #1
SE cable next to coaxial cable
Hi,
Based on advice received in another post...thanks... I am adding a sub panel...
My question: I will be running my new SE cable along side of my Verizon Fios coaxial cable and I would like to know that I will not be causing any interference with the FIOS... guess I could ask verizon too... but thanks if you know the answer.
Sincerely,
Rob
moondog111 is offline   Reply With Quote
Old 11-10-2008, 10:32 PM   #2
It shouldn't cause any problems if it is a good quality coax cable like RG-6.
I like to run all my low voltage cables away from electric lines whenever possible though.
Billy_Bob is offline   Reply With Quote
Old 11-10-2008, 10:36 PM   #3
Res Ipsa Loquitur
Are you sure it is coax and not fiber optic cable? That is what is Verizon's claim to fame with FIOS. If it were optical, there would be no effect on it at all.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 11-11-2008, 07:15 AM   #4
If it is optical there is no possible way to interfere unless your utility knife finds a way across it.
rgsgww is offline   Reply With Quote
Old 11-11-2008, 07:45 AM   #5
Hi,
Thanks for the replies. It is RG-6 coax in the house... I can't speak to what Verizon uses outside...maybe that is the fiber optic. At any rate not alot of options, the best route through my finished basement is inside the box-out for the the center I-beam and ducting trunk. I could try to seperate them on both sides of the beam or somethin... but I am hoping not to have to worry about it.
Ciao,
Rob
Old 11-11-2008, 11:36 AM   #6
DIYer
My rule of thumb is to not worry too much about electrical running next to network.
Assuming the coax is properly terminated and installed right then there's very little bad that can happen.
Just don't crush the coax with a staple.
the best route through ... ducting trunk.
If you run through an air duct it all needs to be plenum rated cable, not PVC insulation.
Gigs is offline   Reply With Quote
Old 11-12-2008, 03:12 PM   #7
thanks... and sorry, I meant I am running the cable next to the duct, alongside the I-beam, in the boxed out ceiling.
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Coaxial Cable blew tv, computer etc... ozflow Electrical 4 10-13-2008 07:06 PM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Coaxial cable problem seaox67 Home Theater 1 04-07-2007 10:49 AM
