Old 11-04-2012, 01:05 PM   #1
which screws for raco 7120 outlet box / for light fixtures
I have a Raco 7120 outlet box in ceiling and #10 10-32 screws don't fit. They are too loose/small for the holes in the outlet box. Do you know which size screws this box uses and if there are cross bars that accept bigger screws? Most cross bars I found at Home Depot seem for 8-32/10-32 max...
stephlosaltos is offline   Reply With Quote
Old 11-04-2012, 01:26 PM   #2
Master Electrician
To my understanding, that assembly does NOT use machine screws. It requires wood screws that are driven through the fan bracket (or fixture strap) directly into a framing member.
brric is offline   Reply With Quote
Old 11-04-2012, 01:45 PM   #3
Licensed electrician
This is the correct answer.
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 11:27 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
