Screwed Wiring Up - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 06:12 PM   #1
Rewards Points: 878
Screwed Wiring up
I put a stringer in my attic and it need to be plugged into an outlet. I picked up power from a box in the attic and ran that 14/2 down the wall to the switch in the pic and then ran another 14/2 up from the switch to the outlet. Well now that switch I installed is controlling my kitchen light. and there is no power at the outlet in the attic no matter what position the switch is in. What did I do wrong? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 04-10-2013, 06:21 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Need to see the box you tapped into.
Where does the cable in the back go?
jbfan is online now   Reply With Quote
Old 04-10-2013, 06:24 PM   #3
Rewards Points: 14,312
A stringer as I understand it is a what stair treads are attached to.
Hardway (04-10-2013)
Old 04-10-2013, 07:38 PM   #4
Rewards Points: 878
I think i tap into the kitchen light..... Lmao....cant do that correct? Where can i take power from for his outlet? Thanks
Old 04-10-2013, 07:58 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It appears you have tied into a switch loop. There is no neutral and is the reason why the receptacle you installed will not work.
Old 04-10-2013, 08:01 PM   #6
Rewards Points: 878
Okay. I have a switch for the kitchen light and i installed the switch in the pic for the attic light. The kitchen switch and that attic switch both now control the kitchen light. Thanks
Old 04-10-2013, 08:07 PM   #7
k_buz's Avatar
I read your post incorrectly. My above post is useless. Sorry about that.
You have a splice mixed up somewhere. I'm assuming its in the JBox you pulled power from, but I can't be sure.
Old 04-10-2013, 08:16 PM   #8
Rewards Points: 878
Yes , there was two seperate 14/2 cables in he box and i added another and ran it to the attic switch then from the switch to the outlet. Thanks
Old 04-10-2013, 09:42 PM   #9
Rewards Points: 512
Go to the attic, and undo what you did.
What is a stringer?
IN the jbox, you need to find a hot and its neutral.
  • The neutral (white) will run to, and terminate at the Silver screw on the Receptacle, as will the hot (BLACK), BUT will not terminate there
  • The hot (BLACK) at the receptacle (from the jbox), will attach to the WHITE* wire running to the Switch
  • the BLACK from the Switch will terminate at the Brass screw on the receptacle
  • Connect both wires at Switch
*I believe that Code requires that you re-identify the White wire in this loop as Black.
Old 04-10-2013, 10:16 PM   #10
Rewards Points: 878
What is a stringer?
  • The neutral (white) will run to, and terminate at the light, as will the hot (BLACK), BUT will not terminate there.
  • The hot (BLACK) at the light (from the jbox), will attach to the WHITE wire running to the switch
  • the BLACK from the switch will terminate at the light.
Ok thanks. So how do i get power to my outler and have it switched? My stringer...kind of like these...http://www.bergeninc.com/electrical-stringers.aspx
Has a plug on the end. Thanks.... Greatly appreciate the help.
Old 04-11-2013, 02:03 AM   #11
Rewards Points: 512
OK, I messed up a bit. Instead of terminating at a light fixture (there is no light fixture), terminate at receptacle: BLACK to BRASS screw, and WHITE to SILVER screw.
Old 04-11-2013, 04:38 AM   #12
Rewards Points: 878
Then go to attic switch?
Old 04-11-2013, 06:29 AM   #13
Rewards Points: 2,516
Like mentioned above locate power in a nearby junction box.
Then either run cable to the outlet first and use a switch loop(left diagram below) or run the cable to the switch first(right diagram below)
Screwed Wiring up-switch-loop-outlet.jpg   Screwed Wiring up-switched-outlet-power-into-switch.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Mstrlucky74 (04-11-2013)
Old 04-11-2013, 06:35 AM   #14
What are you going to use to house the receptacle?? PLastic or metal box?
Old 04-11-2013, 09:38 AM   #15
Rewards Points: 512
Post 9 edited after OP's followup in #12.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
