Old 01-25-2009, 04:25 AM   #1
screw type bulbs.
there are two types of bulb holders.. pin type (benet) or screw type.
my question is, it is hard to screw or unscrew bulbs ( specialy recessed downlights). Specially if I want to replace bulbs. Is there any thing like oil or powder to reduce the friction of the screw type holders.
much appreciated your comments.
mpj111 is offline   Reply With Quote
Old 01-25-2009, 04:53 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
screw type bulbs.
You could try some Dielectric grease to the bulb. which could be bought at any auto parts store. I would put just a small film over the mogul base of the bulb. BOB
Old 01-25-2009, 01:16 PM   #3
Master General ReEngineer
Bondo's Avatar
screw type bulbs.
Ayuh,...
A Quick Shot of spray sillicone on the threaded portion helps Alot....
Old 01-25-2009, 06:48 PM   #4
screw type bulbs.
Not unless you are standing on top of a 16' stap ladder leaning out over some furniture.
220/221 is offline   Reply With Quote
Old 01-27-2009, 03:32 PM   #5
screw type bulbs.
Thank you "Buletbob" & "Bondo".
I used thin film of silicon greese and used rubber glove to handle the bulbs. It seems to be working work.
But I do not know is there any affect to the contacts in the long run when I apply silicon greese .
Old 01-27-2009, 04:27 PM   #6
buletbob's Avatar
screw type bulbs.
Glade to be of any help. BOB
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 09:18 PM
Question about removing a screw type fuse box... OmegaBunny Electrical 9 09-15-2008 11:13 PM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 03:34 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
