Screw Terminals Mid Wire - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 01-26-2010, 10:16 PM   #1
Two part question that where I've seen elsewhere, no one could ever sight code to backup their claim.
1. Is it legal to strip a conductor in the middle, wrap it around a screw terminal, and use the end of the conductor on another device? (I think this might be called a rabbit ear).
Some have claimed this was something allowed decades ago (but I've found rabbit ears in my 12yo home).
Some have claimed that you are not allowed to strip a conductor "in the middle" (therefore making a rabbit ear would be against code).
2. Assuming someone can sight where NEC does not allow #1, what about for grounds? The wire doesn't have to be stripped, so could you use a series of rabbit ears to ground all the switches in a gang box with a single neutral, no pig-tails?
HooKooDooKu is offline
Old 01-26-2010, 10:20 PM   #2
Are you talking grounds....or neutrals ?
You mention both at the same time
You do not use a neutral as a ground
Scuba_Dave is offline
Old 01-26-2010, 10:27 PM   #3
Sorry, typo...
You guys are answering questions so fast (thanks a lot for that by the way) that every answer provided seems to lead me to another question and the cycle continues...
So lets try again:
#1. Does NEC allow striping a conductor (black/white/red) mid-wire for a rabbit ear on screw terminals?
#2. If NEC shoots down #1, can you rabbit ear ground wire since they don't have to be stripped?
Old 01-27-2010, 07:09 AM   #4
Check this thread for discussion:
pig tailing switches
IMO its legal & meets code
Of course an inspector may or may not like it
I've done it in the past, just need to leave enough wire
I just use pigtails now, faster IMO
Old 01-27-2010, 08:18 AM   #5
Actually, I had seen that other thread before I started this one. I did, how ever, fail to realize it was an on-going discussion. When I found it with a search, I assumed it was an old post, and the question of whether it meets code or not seemed to still be open to debate (aside from Scuba_Dave's).
As such, I guess these two threads need to be merged or this one deleted.
Closed Thread
What is the best way to wire this? RST Electrical 8 08-18-2009 11:29 PM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
Wiring around screw terminals daxinarian Electrical 3 07-14-2008 04:41 PM
