-   -   Screw into wiring (http://www.diychatroom.com/f18/screw-into-wiring-136214/)
Master Brian 03-06-2012 06:29 PM
Screw into wiring
The other day I was running a screw into a stud and nicked lightly nicked an electrical line and thus tripped the breaker.
I cut back the insulation/sheathing on the romex wire to inspect and apparently what I hit was mostly the ground wire. There is a small nick out of it, but other than that, couldn't really see any other damage to the remaining wires. The neutral wire was definately not affected as the screw was on the hot wire side, but guessing that the screw must have just lightly nicked the insulation on the hot wire with the thread or tip of the screw.
My question is, is there a safe way to repair this wire WITHOUT having to relace the entire length of wire. As soon as I insected the wires, I flipped the breaker and all was fine again. As a temp safety measure I did wrap the wires with electric tape just to ensure nothing hit them, but if that's not safe then don't want to leave them like that. My biggest concern is the small nick it took out of the ground wire as I don't know what that will do over time.
Thanks for any feedback....
rrolleston 03-06-2012 06:58 PM
Installing a junction box or two to properly splice the two ends together with wire nuts and covering them with blank plates so they can always be accessed.
Msradell 03-06-2012 09:39 PM
Just remember that any boxes you install have to remain accessible! They cannot be hidden within the wall.
frenchelectrican 03-06-2012 09:51 PM
Just before you mudded up the drywall please do the proper repair first either use two junction boxes as other mention otherwise if that is a short run just replace the entire length.
And what size screw you did used ?? if you useing to run the drywall screw you only need 1.25 inch drywall screw that will serve very well.
I have ran into like this pretty often when someone use more than 1.5 inches ( the last one I did see was a good 3 inch drywall screw it took out the house service entrance cable :eek: )
Make sure you keep your romex cable in centre much as possible so that way the drywall screw or nail will not hit them.
Merci,
Marc
rrolleston 03-06-2012 10:41 PM
Ouch lucky their house is still standing. Must have been a mess.
frenchelectrican 03-06-2012 11:24 PM
Yeah but it was a super mess to clean it up have to rip the drywall off to get into the rest of it to make it worst it was allready in the PVC conduit that how it did reduce the damage if not have conduit in there just a plain jane SE cable it will do more damage there.
That was just a stroke of luck on that time and it was good thing the POCO transfomer allready at full load so a good short did blew the fuse out so that is the other factor it was lucky.
Not very often you get that kind of combation of luck at once.
Merci,
Marc
Master Brian 03-07-2012 10:45 AM
As for the screw, it was acutally a 3" - 3-1/2" screw, as I was joining two 2x's together. Thought I was running the screw at more of an angle to avoid the wire, but ended up sinking in deaper at the last second and nicked the wire.
The only real good news is that the wall was freshly stripped of Lathe and Plaster, so everything is exposed. I would love to replace the entire length of wire, but one end is in an unaccessible ceiling filled with cellulose insulation. This is 14/2 wire going from a switch to ceiling lights.
Not really anywhere good to place a junction box, unless I added one inside of a cabinet. The other option if it's ok to do, I could possibly use a nearby receptacle's box and tuck the wire into the back of that box, then put the receptacle, which is on different circuit back in. All that would require is running a new length of wire from switch to receptacle.
rrolleston 03-07-2012 11:00 AM
Having two different circuits joined in one box could be dangerous for someone working on it in the future.
jbfan 03-07-2012 12:13 PM
Not a problem and is done all the time.
If that is what works out best for him, go for it.
Of course, you need to make sure the box is large enough to handle the extra wires.
rrolleston 03-07-2012 12:22 PM
Not a problem if they are on the same breaker. If they are separate circuits then someone could get a surprise if they think everything in there is turned off.
jbfan 03-07-2012 12:29 PM
That would then be their fault for not checking everything!!!!!!!
Yoyizit 03-07-2012 12:53 PM
Yes, you need two to lengthen the wires to give you the required 6" of leads in the box.
ddawg16 03-07-2012 01:01 PM
Ya know....I will most likely catch hell for this....but....since you did not actually break the wire...in other words, it's fully intact....tape sounds like a sound solution...
If it was me....I would pull back the sheath on the Romex...tape the black real good...put the romex sheath back in place...tape the crap out of that...put back in wall....seal up said wall.....
There is no break....hence, no danger of a bad connection....
Yoyizit 03-07-2012 01:11 PM
First, read this site's disclaimers.
Then collect the opinions, facts and reasoning of experienced electricians who object to the method below and then modify the method accordingly.
Posting the reasoning may turn matters of opinion into matters of fact.
To reduce your risk of fire to a level that is down in the noise, surround the repair with two halves of a 3/4" ID length of copper pipe split lengthwise and fastened with a hose clamp. You'll have to splay out one of the pipe pieces so you get some overlap between the pieces.
And to fasten the tape with some fireproof cord/strand/fine wire to prevent it from unwinding without using knots, search on "whipping" which is used to prevent the ends of ropes from fraying.
Master Brian 03-07-2012 01:22 PM
Well, that is what I've for now, but curious what problems that might pose. Really the only real issue I see is if the nick on the ground wire were to cause the ground wire to break, which would leave the lights this goes to without ground. There was no apparent damage to the other wires, other than a nick in the insulation.
With that said, it isn't too much work, if I were to cut the wire and run a new wire from the switch to the receptacles junction box. Problem is I really question if creating a splice is really better than leaving as is, is there really much chance of the nick to the ground wire causing it to break? I would think that might only happen if the wire were to get overtly hot many times over many years. This serves 3 pendant lights and that is it, with most likely never more than 180-200w total. Even then, if it were to break, I'd just be without ground, which I do realize isn't necessarily a great thing, but....how great is that chance?
In any case, it does bug me a little, so I'll likely splice and stick in junction box, even though like I said, I question that as I've seen those splices go bad and actually had one almost catch my house on fire right after buying the house.
As for two circuits in one box, I tend to somewhat agree, if someone isn't smart enough to test all wires in a box, maybe they shouldn't be in there, especially since there will then be two different gauges of wire inside the box.
