Scraped Insulation After Pulling - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2009, 11:36 PM   #1
scraped insulation after pulling
After I pulled 14 AWG THHN through EMT I noticed some scrapes in the insulation. The outer layer which was clear was roughed up a bit and had several small tears in this layer. The underlying insulation appeared to be fine.
Is this common? Is is a concern?
measure thrice is offline   Reply With Quote
Old 02-19-2009, 12:15 AM   #2
Yes and....depends. Be careful next time
220/221 is offline   Reply With Quote
Old 02-19-2009, 12:38 PM   #3
Rewards Points: 246
Minor scrapes of the thermoplastic covering are not a concern. Cuts and scrapes that affect the actual insulation could be a problem.
My concern would be how you pulled these conductors to cause the issue.
Tags
insulation damaged
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
