Sconce Placed In Studs? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 06:34 PM   #1
Sconce placed in studs?
Hey,
I got a problem...
I was planning to put sconces on each side of a bathroom mirror. But, the location of the mirror means that the sconce boxes would have to be put into the studs. See pictures. The cardboard cut out gives the dimensions of the mirror. Furthermore, the right sconce would right over the trim of the closet.
1. Can I put these sconce boxes in these studs?
2. Should I just do lighting over the mirror? I was considered doing this in addition to the sconces.
3. If I don't use the sconces on the sides of the mirror, are there any other places in the bathroom to put them? I already bought them and they match the bathroom sink faucet.
I can't move the mirror much to the left because the toilet is going to be right there. It's a tight fit as it is.
Any inspiration?
Red
RedBear is offline   Reply With Quote
Old 02-03-2010, 06:55 PM   #2
Why not mount them to the sides of the studs ?
Its only another 3" or so
Or is that a doorway in the 2nd pic...so that would not work ?
They do make pancake boxes that might work - depends upon the sconce base
Old 02-03-2010, 07:19 PM   #3
Thumbs up
Exactly my idea! But then he would have to use different boxes (Dry wall boxes)!
spark plug is offline   Reply With Quote
Old 02-03-2010, 07:29 PM   #4
Household Handyman
Rewards Points: 1,408
Those appear to be older true 2x4 studs, a lot of wood. Why not use "pancake boxes"? They are thinner than the boxes shown, you could into the studs only deep enough for the boxes. Everything will fall into place rather well. David
Old 02-03-2010, 08:15 PM   #5
Yes, the beam that the right sconce box is on is the frame for the bathroom closet. Moving the right sconce three inches over would put it on the closet door or in the closet.
I am not familiar with pancake boxes. I will look into them. How can I tell if my sconces will work with pancake boxes?
Thanks, guys, you are quite inspirational!
Red
Old 02-03-2010, 08:19 PM   #6
Bring a sconce with you & see if it fits in the base
I use the metal ones
Old 02-03-2010, 08:27 PM   #7
Licensed electrician
Rewards Points: 1,876
A pancake box only has enough cubic inch capacity to allow one 14-2 cable. Unless the canopy is marked with its cubic inch capacity that volume does not count.
Old 02-03-2010, 08:27 PM   #8
Those pancakes look so good I reached for the syrup. I'll give it a try!
Thanks for solving another one!
Old 02-03-2010, 09:16 PM   #9
Thumbs up
Red
Yes. The spacing on the box or crossbar assembly is the same. Either with 6-32 or 8-32 screws. (The pancake boxes use 8-32 screws.)! So. It's a YES. 2-1!
Old 02-04-2010, 08:26 AM   #10
Rewards Points: 50
f you use the pancake boxes don't feed the cable through the middle knock-out.The mounting bolt for your light might need that space
daveb1 is offline   Reply With Quote
Old 02-04-2010, 08:41 AM   #11
Just call me Andrew
Rewards Points: 1,020
I meant to post these yesterday. These are from the New York State building code, it should be verified with your locality, but chances are they are similar or identical. You could cut a notch in the front of the stud and mount the box right over it, allowing you to run the wire in behind.
Andrew
secutanudu is offline   Reply With Quote
Old 02-04-2010, 08:21 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
you beat me to it!
plummen is offline   Reply With Quote
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 03:20 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
