Sconce Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2008, 10:12 AM   #1
sconce lighting
I want to install 2 sconce in my basement, what is the correct box size for these? Will a regular outlet box work? Thanks
helpless handyman is offline   Reply With Quote
Old 04-01-2008, 12:24 PM   #2
Rewards Points: 150
helpless (definitely),
use the round / octagon boxes..
JGarth is offline   Reply With Quote
Old 04-01-2008, 12:53 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Sconces can be a different duck than other fixtures, just depends on the style of sconce and its canopy that covers the wall electrical box. Some sconces require 3 1/2" or 3 1/4" round or octagon boxes. Some will be fine with a 4 inch round or octagon. You also need to be aware of old work boxes (if plastic) that are 4 inch and have a 3/8 to 1/2 inch lip that rides the outside of your finished wall, these may not cover with some styles of sconces..in particular the ones that are half moon shaped like this....
Let the canopy be your guide as to the box size you need....
Old 04-02-2008, 12:51 PM   #4
Learning by Doing
Leah Frances's Avatar
I want to hang some sconces too. But, I do not have enough room for the standard 4 inch oct box (the box has to go into a framed cavity only 3 inches wide). It seems like 314.27's exception would allow me to use an outlet box if my sconce weight is under 6 lbs. Is this correct?
Am I apt to find much selection with the (assumed) restriction?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-02-2008, 05:00 PM   #5
Licensed electrician
Rewards Points: 1,246
This might be what you need.
http://www.aifittings.com/whnew95.htm
Old 04-02-2008, 05:33 PM   #6
Learning by Doing
What is the side to side dimensions of this? The webpage says 3.5 inch "hole saw". I don't need to drill a hole - but I only have 3 inches of width to work with. thanks
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 12:50 PM
Calculating lighting wbjdmd Electrical 18 11-01-2006 06:18 PM
