-   -   sconce lighting (http://www.diychatroom.com/f18/sconce-lighting-19360/)
helpless handyman 04-01-2008 09:12 AM
sconce lighting
I want to install 2 sconce in my basement, what is the correct box size for these? Will a regular outlet box work? Thanks
JGarth 04-01-2008 11:24 AM
helpless (definitely),
use the round / octagon boxes..
Stubbie 04-01-2008 11:53 AM
Sconces can be a different duck than other fixtures, just depends on the style of sconce and its canopy that covers the wall electrical box. Some sconces require 3 1/2" or 3 1/4" round or octagon boxes. Some will be fine with a 4 inch round or octagon. You also need to be aware of old work boxes (if plastic) that are 4 inch and have a 3/8 to 1/2 inch lip that rides the outside of your finished wall, these may not cover with some styles of sconces..in particular the ones that are half moon shaped like this....
http://www.thelightshop.com/v/vspfil...tos/WS56-1.jpg
Let the canopy be your guide as to the box size you need....:thumbsup:
Leah Frances 04-02-2008 11:51 AM
I want to hang some sconces too. But, I do not have enough room for the standard 4 inch oct box (the box has to go into a framed cavity only 3 inches wide). It seems like 314.27's exception would allow me to use an outlet box if my sconce weight is under 6 lbs. Is this correct?
Am I apt to find much selection with the (assumed) restriction?
Jim Port 04-02-2008 04:00 PM
This might be what you need.
http://www.aifittings.com/new_images...7R-product.jpg
http://www.aifittings.com/whnew95.htm
Leah Frances 04-02-2008 04:33 PM
What is the side to side dimensions of this? The webpage says 3.5 inch "hole saw". I don't need to drill a hole - but I only have 3 inches of width to work with. thanks
