Schedule 40 Or 80? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 09:11 PM   #16
Electrical Contractor
LOL. It's getting late.
hpp58 is offline   Reply With Quote
Old 05-28-2011, 12:12 AM   #17
Rewards Points: 31
Thanks for all the advice guys! I have all of the above tools -- which one produces the cleanest, squarest cut? I'm betting miter saw...am I right?
lesp is offline   Reply With Quote
Old 05-28-2011, 05:23 AM   #18
I have found that every single time i've cut pvc, be it with a hacksaw, mitersaw, or chewed thru it with my teeth, it always looks perfectly clean and square once it is shoved into a coupling or connector.
AndyinAtl is offline   Reply With Quote
The Following User Says Thank You to AndyinAtl For This Useful Post:
jbfan (05-28-2011)
Old 05-28-2011, 05:37 AM   #19
Licensed electrician
Rewards Points: 1,622
The miter saw will give the the cleanest, most square cut. Be sure to ream the inside cut edge with a file.
Schedule 40 under driveway brjl Electrical 11 04-06-2011 07:32 PM
Illustrated nailing schedule? cortell Building & Construction 6 11-29-2010 09:26 PM
Using schedule 40 black pipe spaceman spif Plumbing 5 04-27-2010 05:37 PM
Primer/Topcoat Schedule for Trim? Lovegasoline Painting 26 12-19-2009 04:15 AM
OK to use schedule 40 & 80 conduit? Plumbvoltage Electrical 2 05-19-2009 02:27 PM
