Scary Fan Install. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 05:55 PM   #1
Scary fan install.
I just took down a fan to rewire part of a circuit that passed through the box. I found that the box was secured by only this.
Romex is pinched between bracer and box
Screw comparison with B-cap
rgsgww is offline   Reply With Quote
Old 02-22-2009, 06:01 PM   #2
At least it had coarse threads
220/221 is offline   Reply With Quote
Old 02-22-2009, 06:03 PM   #3
Electrician
Thats not scary. when you take one down thats been installed to a plastic box, now thats scary, the only difference is usually they are already down when you get the call.
chris75 is offline   Reply With Quote
Old 02-22-2009, 06:29 PM   #4
This house was remodeled, so a permit was pulled and all, the ceiling is original from the 1960s, so it must have slipped by.
Makes me want to check areas with plastic boxes. Seriously? they were already down. Wonder what it sounds like.
Old 02-22-2009, 06:33 PM   #5
Electrician
Amazingly, the wires always hold them up. But I did see one once installed onto an old work plastic box...
Old 02-22-2009, 06:36 PM   #6
Tells you how strong stranded to solid connections can be sometimes.
Old work box? I would expect the drywall to come down right when you hang it. Those things are rated for like what, 5 lbs.
Old 02-22-2009, 06:40 PM   #7
Household Handyman
Rewards Points: 1,408
I've had calls for those infamous "hanging ceiling fans" myself. I have always found the fans with ceiling box and attached wiring just hanging there. This is usually the result of a homeowner installing the ceiling fan without checking to see if the ceiling box is secured well enough to hang it on. Some of these fans/lights have been, in my opinion, heavy enough they should have pulled one or more wiring connections loose but just did not at that time. Maybe it's saying a lot for the wiring connection, or the wire nuts, or just plain old good luck. IF I can access the top of this ceiling, such as the attic, I will convince the homeowner the necessity of a strong wood brace added to hang the new metal box. It's not easy but I have added a wooden brace through the outlet box hole using screws on a "toe-nail" pattern into the ceiling joist(s). You never know what you will run into working with the public. Thanks, David
Old 02-22-2009, 09:28 PM   #8
Rewards Points: 278
I just checked the fan I removed and I guess it's worse than yours, nailed plastic box..
I don't understand why people think they can just change any ceiling light into a fan just because they had $50.. it's over their dinner table and son's bed..
DIYGST is offline   Reply With Quote
Old 02-22-2009, 09:34 PM   #9
According to my "electrician," you can use any box you want with a fan as long as it's attached to a framing member.
pmoe is offline   Reply With Quote
Old 02-22-2009, 09:36 PM   #10
Electrician
Yes, this is correct.
Old 02-22-2009, 09:42 PM   #11
Doesn't the box have to be rated for a fan?
Old 02-22-2009, 09:46 PM   #12
Electrician
No, check out 314.27 (D) along with 422.18
Old 02-22-2009, 09:54 PM   #13
Thats good to know, I was wondering since I just found out I got a non fan rated pancake box.
Old 02-22-2009, 09:57 PM   #14
Electrician
I would just screw the fan bracket to the structure. You still need the box of course.
Old 02-22-2009, 09:57 PM   #15
I read "marked by their manufacturer as suitable for this purpose" as "fan rated box"
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 11:56 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 10:16 PM
