Saving Money By Using 12 AWG On 15amp Circuits? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 10:48 AM   #16
Originally Posted by Jim Port View Post
Sounds like the circuits were not laid out properly and in consideration of the expected loads.
you are 100% correct, unfortunately i dont own the house and have to deal with it. you should see the diagram for this mess, i had to trace all the lines since it was never done. i've talked with the owner but he's not willing to let me re-run the lines.
that said, i took it upon myself to replace the 15amp with 20amp, first checking to see the wires could handle it. saves me having to walk down stairs every time an accidental trip occurs.
outspoken is offline   Reply With Quote
Old 04-29-2012, 11:19 AM   #17
Licensed electrician
Rewards Points: 1,230
Sounds like you don't own this property, as such you should not have touched anything. You have created a potential fire hazard in someone elses property. Rarely is an undersized fuse or breaker installed.
Old 04-29-2012, 12:06 PM   #18
My only reason for replying to this thread was to say there is not a waste of 5 amps when installing a 20amp for a 15amp application. If there is, on what grounds would that be?
Old 04-29-2012, 03:29 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
First off, what is your profession? Are you an electrician or electrical contractor? Carpenter? Handyman?
Second, RE-READ what I wrote. I said "a POTENTIAL 5 amps". Meaning the circuit would trip 5 amps sooner. So the added POTENTIAL 5 amps worth of circuit would prevent a decent amount of tripping IMO.
I also agree with Jim. You SHOULD NOT be touching ANYTHING electrical in a place you rent. ESPECIALLY after the LL told you not to.
Old 04-29-2012, 09:37 PM   #20
Rewards Points: 150
POTENTIAL is voltage not amperage.
The size of the service is based on the size of the dwelling, plus special circuits, not the number and size of standard circuits, nor the size of the breaker box.
goosebarry is offline   Reply With Quote
Old 04-29-2012, 10:27 PM   #21
I=E/R
a7ecorsair's Avatar
Potential used as a noun could be voltage but when used as an adjective means possible.
And your response in Post #13
The reason to use 20amp would be to prevent the potential trip.
a7ecorsair is offline   Reply With Quote
Old 04-29-2012, 10:30 PM   #22
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It seems like people just like to argue.........
The Following User Says Thank You to k_buz For This Useful Post:
goosebarry (04-30-2012)
Old 04-29-2012, 10:40 PM   #23
in the iec world, voltage is tension.
itsnotrequired is offline   Reply With Quote
Old 04-29-2012, 10:43 PM   #24
I=E/R
a7ecorsair's Avatar
As in High Tension
Old 04-29-2012, 10:46 PM   #25
Originally Posted by a7ecorsair View Post
As in High Tension
i thought that was because of the physical tension on the actual wires between the transmission structures.
Old 04-29-2012, 10:53 PM   #26
I=E/R
a7ecorsair's Avatar
From an on-line dictionary:
5. physics a. voltage, electromotive force, or potential difference b. ( in combination ): high-tension ; low-tension
Old 04-30-2012, 06:36 AM   #27
WHO is talking about voltage??? And I am NOT talking about "voltage potential", such as with pools.
Are you even reading the replies?
WHAT in the world are you talking about???
WHO said anything about the service size?
Old 04-30-2012, 07:54 AM   #28
Rewards Points: 3,256
As in High Tension
High Anxiety is more fitting.
Love the movie too!
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 10:06 AM
Smoke Detectors on Different Circuits Mililani Electrical 13 10-17-2010 07:35 PM
Multiple circuits losing power Skip72 Electrical 6 09-20-2010 11:27 AM
How many circuits for bedrooms? Clutchcargo Electrical 5 08-10-2010 10:40 AM
I'm all about saving money on electricity but what is this? imola ghost Electrical 15 09-09-2008 09:36 PM
