Samsung TV Extension Power Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 05:04 AM   #1
Samsung TV Extension Power cord
I need to buy a 15' power cord for my new Samsung TV with an L-shape that plugs into the TV.
Where can I find that?
Olgian77 is offline   Reply With Quote
Old 06-24-2012, 06:21 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I would start with Samsung... Give them a call.
Old 06-24-2012, 06:27 AM   #3
"L" shaped like this?
That is on this site:
http://www.americord.com/media/catalog/category/5-15p_20to_20c-13ra_1.jpeg
But if this is it, they are pretty common. Any decent electronics store or department should have them.
Gary
garyoutwest is offline   Reply With Quote
Old 06-24-2012, 12:14 PM   #4
Semi-Pro Electro-Geek
Search around online (Amazon and Newegg would be good places to look) for "IEC" cords. That's the name of the standard power connector on the TV.
mpoulton is offline   Reply With Quote
Old 06-24-2012, 12:59 PM   #5
Rewards Points: 6,652
monoprice, radioshack, partsexpress. Also, you are better locating a outlet nearer to the tv, than run a 15 foot cord.
The Following User Says Thank You to gregzoll For This Useful Post:
CopperClad (06-24-2012)
Old 06-24-2012, 04:15 PM   #6
Agreed. Pretty sure the code stating an outlet every 6' are to prevent people from running 15' extension cords to their tv's.
CopperClad is offline   Reply With Quote
Old 06-24-2012, 04:46 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no such code requiring an outlet every 6 feet.
Old 06-24-2012, 05:04 PM   #8
NEC2005 Article 210.52(A)(1)SPACING. Recepticles shall be installed so that no point measured horizontally along the floor line in any wall space is more than 1.8m(6') from a recepticle outlet. Also NEC2005
Old 06-24-2012, 05:12 PM   #9
sorry. I think I copy and pasted that from a yahoo answer.. I can't find it but I could have swore in the 2011 NEC update they changed it to 6'..
Old 06-24-2012, 08:40 PM   #10
k_buz's Avatar
Nope
Old 06-24-2012, 09:11 PM   #11
Here k_buz, since you seem to think that it is FUD:
http://www.ezdiyelectricity.com/?p=95 I will give you a clue. 210.52(A)
Old 06-24-2012, 09:14 PM   #12
Yeah, that's the old one I posted as well.. I could have swore I read some where that they did change it to every 6' in the 2011 update.. I couldn't find it though.. And I'm not paying to download it. I gave up looking. So I guess it's still the same..
Old 06-24-2012, 09:21 PM   #13
k_buz's Avatar
And I suppose you install counter top receptacles every 2' as well.
(1) Spacing. Receptacles shall be installed such that no
space is more than 1.8 m (6 ft) from a receptacle outlet.
Can you tell me where it says that outlets have to be spaced 6' apart?
Old 06-24-2012, 09:47 PM   #14
Licensed electrician
Rewards Points: 1,788
You won't find the change to every 6'. It was not changed.
Old 06-25-2012, 04:38 AM   #15
E2 Electrician
I love the imaginary code sightings we get on here.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (06-25-2012)
Cut through extension cord Sliding Man Electrical 10 11-14-2011 09:56 PM
Permanent wire vs. extension cord Piedmont Electrical 7 05-04-2011 04:32 PM
TV power cord extention requirement cece Electrical 16 09-28-2010 03:53 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
Extension Cord Question. camoram Electrical 2 04-08-2006 09:12 PM
