Same Lights Much Brighter After Rewire? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 08:34 PM   #1
Same lights much brighter after rewire?
I did a rewire of two lights so they share the same switch. I did everything right. Now Ive noticed that the lights are much brighter. What happened? No, nothings wrong Im just curious. Ive checked the wires for 220v because Ive heard this happens with 220v but I just get 120v. Did rewiring the common cause a better connection?
rgsgww is offline   Reply With Quote
Old 07-09-2008, 08:54 PM   #2
Licensed Pro
Maybe they were wired incorrectly (in series) before and you inadvertently fixed it.
Old 07-10-2008, 11:06 AM   #3
Rewards Points: 246
Did you clean the globes, bulbs anything glass?
Old 07-10-2008, 12:06 PM   #4
lol not really. I think its just tightened connections, this circuit shares a common for a furnace, 1 bedroom, a bathroom and a freezer. And after 7-8 years after a remodel. Connections can loosen up.
Old 07-11-2008, 12:20 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Now that is a bit of load there if someone run the hair dryer in bathroom and the furance is running it will be surefire the breaker will trip no question asked there so down the road it will be wise to seprated them a bit when you get there.
Merci,Marc
Old 07-11-2008, 08:11 AM   #6
Shouldn't the furnace have it's own dedicated line?
Maybe code doesn't require it, but sure makes sense to me. You wouldn't want to be in the cold because your hair dryer tripped the breaker.
FW
fw2007 is offline   Reply With Quote
Old 07-11-2008, 12:42 PM   #7
FW
It does actually. There are 2 breakers, both 15 amp, there is 14/3 wire. The red wire is connected to one 15 amp and the black to another 15 amp. In the junction box the red wire is connected to another line going to the furnace. And the black line goes to everything else. The furnace and everything else share a neutral. I would run its own line though.
Old 07-11-2008, 12:44 PM   #8
Merci,Marc
The furnace is on its own breaker, they just share a neutral. I would still run a new line to it and free up that neutral, those furnace motors send back alot of dirty electricity.
Old 07-11-2008, 01:37 PM   #9
I assume you mean incandescent lamps.
If the voltage to your lamps is 120v + 10% you are shortening their service lifetime. A 10% increase in lamp voltage means you'll get 100x(1.1^[-12]) = 30% of normal service life.
If you're comfortable around electricity, I'd look for a bad connection on your neutral, which means heavy loads on one side of the 240v are seeing less than 120v and the loads on the other side of your neutral are seeing more than 120v. The total must add to 240v.
Any voltage drop across a bolted connection should be less than 30 millivolts.
If you're not comfortable around electricity, I recommend Googling the exact phrase
electrical safety
You should get 1.9 megahits.
Old 07-11-2008, 01:54 PM   #10
electrical safety
Thanks, I will check for a loose neutral in my service panels and a few junction boxes.
Old 07-12-2008, 09:08 AM   #11
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Says who?
John
jrclen is offline   Reply With Quote
Old 07-12-2008, 01:45 PM   #12
Originally Posted by jrclen View Post
Says who?
Maybe not the new ones...mines old...some motors do that.
Tags
lights brigther romex bx
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 02:34 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
