Same Ground 2 Circuits? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 09:09 PM   #1
Ravenworks's Avatar
Same ground 2 circuits?
I know the answer is probably no,but I have to ask.
I am going to pull seven - #10 wires in a 3/4" conduit, (two hots,two neutrals and insulated ground, one circuit is for cloths dryers and one for central A/C.
My intentions are for future proofing if we ever get a new dryer and I like the idea of running an insulated ground for the A/C as well.
The only reason I ask is because I'm down to the last two wraps on my spool of #10 green,if I have to buy more it's not a problem.
Ravenworks is offline   Reply With Quote
Old 03-08-2012, 09:31 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Sure, multiple ciruits use the same ground all the time.
The ground wire must be sized to the largest circuit in the pipe.
The conduit can serve as the ground also!
Old 03-08-2012, 09:34 PM   #3
Missouri Bound's Avatar
I just wonder how #10's are enough for AC and a dryer.....hmmm....and two hots, two neutrals and a ground is only 5 wires. What am I missing?
Do you want it your way or the right way?
Old 03-08-2012, 09:48 PM   #4
jbfan's Avatar
Rewards Points: 140
Missed that
I hope he means 2 hot per.
Old 03-08-2012, 10:09 PM   #5
Licensed electrician
Rewards Points: 1,024
Two hots for the dryer, two hots for the A/C, one neutral for the dryer, one ground for both.
Old 03-08-2012, 10:24 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
This sounds right to me.
Old 03-08-2012, 10:59 PM   #7
Ravenworks's Avatar
Jim you are right.
I had upgraded my service (permitted) and the company that did it are friends of the family,everything is new from the service drop through out the whole house.
Last week I went down to their shop asking for the bill and he wouldn't charge me ,so I feel bad about calling him.
To make matters worst there were 3 spools of #12 (Grn,Wht, Blk) and 4, 1/3 full spools of # 10,( Wht Blue,Blk and Grn) and 75 feet of #4 bare and a big box of fittings.
With a note - " saying finish up the basement and these two circuits before my final inspection."
Multiple Ground Rods, help Ralph III Electrical 72 02-14-2012 10:31 PM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
