Safety Switch For Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 06:26 PM   #1
Rewards Points: 14
safety switch for generator
We recently got a 7000W blackmax generator. I want to install a double throw switch to go between the breaker box main (common), the generator, and the power company line. The breaker box is a crouse-hinds E26095. I found a double throw switch at home depot (http://www.homedepot.com/webapp/wcs/...&Ntpc=1&Ntpr=1).
Would this switch be adequate for the breaker box?
Thanks.
soma is offline   Reply With Quote
Old 11-06-2011, 06:35 PM   #2
Sparky
Rewards Points: 510
would be acceptable with a neutral kit, assuming incoming service is 100A or less. you would also have to remove the Neutral/ground bond in your main panel, as the double throw switch would become the 'first means' of disconnect.
Techy is offline   Reply With Quote
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
