Safety Concerns Of Edison Lamp Outlet Adaptors - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 07:32 AM   #16
Question
The problem was that they were all burnt out at exactly the same time. There was two of them that suffered that fate.
Mikon8er is offline   Reply With Quote
Old 12-08-2011, 12:03 PM   #17
seansy59's Avatar
Rewards Points: 258
My grandmother used to have those edison sockets in the bare bulb fixtures in the basement.
They each ran a fluorescent strip light. Safe? Yes and no. It was way under the limit as far as wattage/amperage goes, so it was not being overloaded. It was pretty much the same as a 40 watt bulb in the fixture.
BUT! The cord for one of the fluorescent lights was an old grounded 3 prong cord. It was plugged into a small brown extension cord with the grounding prong bent outward. Then plugged into the edison socket.
Also plugged into that small brown cord, which wasn't intensionally done because the lamp socket was around the corner, was a cord running to a workstation and another to a fan. The little outlet socket was burnt into the lampholder from heavy load probably peaking 1,000w or more at times! The breaker/or fuse never blew/tripped either because it never exceeded the household wiring capacity. Usually 1,875w 15a.
They are safe if use right. But you have the people that "don't know anything" and think "if it fits, it works!" Best bet is DON'T use them. In fact, they should stop selling them because of the high risks of accidental misuse.
If you have a fixture that you want to plug something into, its easy to tap off of that or a nearby source with the correct gauge wire, connections and box, to install an outlet that will give you all the power you need.
Or, remove the light, and put an outlet right into the box. They are interchangeable. Just make sure that the wiring gauge is correct inside the box that matches the fuse/breaker.
seansy59 is offline   Reply With Quote
Old 12-08-2011, 12:27 PM   #18
Mad Scientist
Not too drift the topic too much, but here's why that happens:
When one bulb in a christmas light string burns out, a shunt in the bulb closes, so current can still flow and the rest of the bulbs remain lit. When this happens, the current through the whole string increases slightly. When more than one or two bulbs are shunted, current through the string rises to the point that the rest of the bulbs can't handle it, and they all burn out nearly instantaneously.
McSteve is offline   Reply With Quote
Old 12-08-2011, 05:13 PM   #19
dmxtothemax's Avatar
Rewards Points: 5,100
This is very true !
But most people with light displays dont understand this.
As they only have the barest knowledge.
dmxtothemax is offline   Reply With Quote
Tags
adaptors , bulb , light , outlet , socket
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-04-2011 12:41 AM
GFCI with 12/2 wire Safety Question Coors Electrical 8 03-09-2010 05:53 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
