Safety Concern Al Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 07:36 AM   #1
Rewards Points: 156
Safety concern Al wiring?
House was built in 1930. Wiring is knob and tube. I am trying to get rid of the knob and tube a little at a time. While doing renovations I found that a previous home owner has done his own wiring. Found 2 junction boxes behind walls, which I know is against code.
The main thing that concerns me is that he has connected new copper to the old knob and tube. I know that aluminum to copper connections must be done with special materials to be safe, but I am not sure if the knob and tube is aluminum. There are no signs of overheating of the wires and the wirenuts that he used are still in tact, which leads me to believe that the wiring is not aluminum. If it's not Al, what material can it be and is it safe to connect it to copper? I'm not sure how many more junction boxes may be hidden.
Branden is offline   Reply With Quote
Old 01-10-2011, 07:58 AM   #2
Rewards Points: 156
I ask because the knob and tube is not the color of copper. I did a little research and think it may be tinned copper or plated copper. Was aluminum wiring used in the 1930s?
Old 01-10-2011, 07:59 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,... All the knob, 'n tube wiring I've replaced was Copper...
The Following User Says Thank You to Bondo For This Useful Post:
Branden (01-10-2011)
Old 01-10-2011, 08:04 AM   #4
Rewards Points: 482
Cut a piece and see if it is copper. I bet it is.
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
Old 01-10-2011, 08:15 AM   #5
Rewards Points: 156
Del,
I'll be sure to take a close look at the wire after work today. Knowing that it is most likely copper will help me sleep better at night. Thanks.
Old 01-10-2011, 09:15 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
All the K&T I have ever seen is copper.
While K&T can be left in place and used, you are not allowed (by code) to add to or extend K&T. That means you are not supposed to making connections to it. Although I believe you can make a connection to K&T for the purpose of a new service panel upgrade.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 01-10-2011, 09:21 AM   #7
Rewards Points: 156
RJ,
I understand that this is not allowed. The fact of the matter is that these connections were made by a previous owner. I am in the process of making it right, and during the process I have found J-boxes behind walls with the K&T extended. My concern with the safety of the Al-Cu connection was for the possibility of other J-boxes done the same way that I have not yet found. Thanks for the info though.
Old 01-10-2011, 02:35 PM   #8
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Never seen aluminum K&T it is probably "tinned" copper wire.
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
The Following User Says Thank You to sparks1up For This Useful Post:
Branden (01-11-2011)
Old 01-10-2011, 04:22 PM   #9
Scared Electrician
Saturday Cowboy's Avatar
Al wire didn't exist until long after K&T had fellin out of favor. You can bet its tinned coper.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 08:49 PM
wiring overkill????? choda_boy_04 Electrical 8 01-01-2009 12:54 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Halogen light - wiring safety Arndavis Electrical 4 08-11-2007 02:30 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
