Old 12-26-2007, 12:23 PM   #1
safe wiring?
I replaced 2 old receptacles with 2 new ones and then the push-button breaker wouldn't reset. I had placed a ground wire from the metal outlet box to each new receptacle. the boxes already have ground wires from the cable in the wall. The breaker finally reset when I removed the ground wires that I connected from the outlet box to the receptacle. Is this safe?
Christo is offline   Reply With Quote
Old 12-26-2007, 12:51 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
safe wiring?
If the boxes are grounded, then running a wire to the outlet from the metal box, is just double grounding. Run the ground wire from the romex to the GFCI, and you should be fine.
Old 12-26-2007, 01:07 PM   #3
safe wiring?
I'm not using GFCI outlets.
Old 12-26-2007, 03:25 PM   #4
gregzoll's Avatar
safe wiring?
Then you have a short somewhere, that was caused when you connected from the outlet ground to the box ground. Double check everything.
Old 12-26-2007, 04:10 PM   #5
safe wiring?
You may have just shorted out the bare recep ground wire on a hot terminal/wire when you folded it back into the box.
220/221 is offline   Reply With Quote
Old 12-26-2007, 11:29 PM   #6
Union Electrician
goose134's Avatar
safe wiring?
That is exactly what I was thinking.
goose134 is offline   Reply With Quote
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 11:50 AM
