Is This Safe? Will It Pass Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 09:09 PM   #1
Rewards Points: 28
Is this safe? Will it pass code?
Hello All,
I've wired some wall sconces (4 of them) with a set of three way switches. When I wired them, I did it wrong. When I first set it up, it was like this:
Supply -> Switch (2 wire)
Switch -> Light 1 (3 wire)
Light 1 -> Light 2 (3 wire)
Light 2 -> Light 3 (3 wire)
Light 4 -> Switch (3 wire)
I realized that I did it wrong when the board was up and taped, so it was to late for me to run 2x14/2 in between the lights. As a result, I re-wired the switches like so:
Supply -> Switch 1 (2 wire)
Switch 1 -> Switch 2 (3 wire)
Switch 2 -> Light 1, Light 2, Light 3, Light 4
I still have 3 wire running in between each light fixture, but with this setup (Supply -> Sw 1 -> Sw 2) I only need 2 wire from Sw2 all the way through Light 4.
Question:
Is it safe to leave the 3 wire between each light fixture? If so, should I cut off the red wire, cap it off or connect it into the black wire?
Will it pass final inspection?
Note: I live in Ontario, so this is the electrical code I'm concerned with.
jim.thornton is offline   Reply With Quote
Old 09-30-2010, 09:17 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if this was the US, there wouldn't be a problem with the spare wire. Just cap it in each light box. (again in the US) you cannot parallel the wires. (illegal due to the size).
I would suggest leaving the typical 6" tail in case you find a need for it in the future. Obviously put wire nuts on all ends.
I know it is not definitive but the more I read from my Canadian brothers of the spark, NEC and CEC is similar in many aspects.
hang on for one of the Canadian guys to either confirm or tell me I am wrong.
regardless of it being legal or not, it is not unsafe.
Old 09-30-2010, 09:21 PM   #3
Rewards Points: 28
Perfect... I didn't think tying the red into the black would be a good idea, but wasn't sure.
Thanks for your help, I'll wait for some Canadian advise to confirm.
Old 09-30-2010, 09:28 PM   #4
joed's Avatar
Rewards Points: 12,924
Same advise. Leave the red wire capped in the back of the box. Never know when you might want if for something like a fan power.
Old 09-30-2010, 09:59 PM   #5
Rewards Points: 28
Thank you. Should I cap off the red wires in every box, or should I connect the red in the middle boxes and cap off the ends?
Old 09-30-2010, 10:25 PM   #6
nap
You talking to me?
nap's Avatar
wouldn't make much difference in my mind.
everything there is pretty much disconnected anyway
Old 10-01-2010, 06:58 AM   #7
Rewards Points: 1,514
Do not cut off the loose ends.
Old 10-01-2010, 02:53 PM   #8
joed's Avatar
Cap the two red together with one wire nut instead of two separate ones. Wire nuts count for box fill in CEC.
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 09:35 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 09:43 AM
What is the smallest shower that code will allow? jaes Building & Construction 4 05-03-2008 06:55 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 04:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
