-   -   Is this safe? Will it pass code? (http://www.diychatroom.com/f18/safe-will-pass-code-82759/)
jim.thornton 09-30-2010 09:09 PM
Hello All,
I've wired some wall sconces (4 of them) with a set of three way switches. When I wired them, I did it wrong. When I first set it up, it was like this:
Supply -> Switch (2 wire)
Switch -> Light 1 (3 wire)
Light 1 -> Light 2 (3 wire)
Light 2 -> Light 3 (3 wire)
Light 4 -> Switch (3 wire)
I realized that I did it wrong when the board was up and taped, so it was to late for me to run 2x14/2 in between the lights. As a result, I re-wired the switches like so:
Supply -> Switch 1 (2 wire)
Switch 1 -> Switch 2 (3 wire)
Switch 2 -> Light 1, Light 2, Light 3, Light 4
I still have 3 wire running in between each light fixture, but with this setup (Supply -> Sw 1 -> Sw 2) I only need 2 wire from Sw2 all the way through Light 4.
Question:
Is it safe to leave the 3 wire between each light fixture? If so, should I cut off the red wire, cap it off or connect it into the black wire?
Will it pass final inspection?
Note: I live in Ontario, so this is the electrical code I'm concerned with.
nap 09-30-2010 09:17 PM
if this was the US, there wouldn't be a problem with the spare wire. Just cap it in each light box. (again in the US) you cannot parallel the wires. (illegal due to the size).
I would suggest leaving the typical 6" tail in case you find a need for it in the future. Obviously put wire nuts on all ends.
I know it is not definitive but the more I read from my Canadian brothers of the spark, NEC and CEC is similar in many aspects.
hang on for one of the Canadian guys to either confirm or tell me I am wrong.
regardless of it being legal or not, it is not unsafe.
jim.thornton 09-30-2010 09:21 PM
Perfect... I didn't think tying the red into the black would be a good idea, but wasn't sure.
Thanks for your help, I'll wait for some Canadian advise to confirm.
joed 09-30-2010 09:28 PM
Same advise. Leave the red wire capped in the back of the box. Never know when you might want if for something like a fan power.
jim.thornton 09-30-2010 09:59 PM
Thank you. Should I cap off the red wires in every box, or should I connect the red in the middle boxes and cap off the ends?
nap 09-30-2010 10:25 PM
wouldn't make much difference in my mind.
everything there is pretty much disconnected anyway
AllanJ 10-01-2010 06:58 AM
Do not cut off the loose ends.
joed 10-01-2010 02:53 PM
Cap the two red together with one wire nut instead of two separate ones. Wire nuts count for box fill in CEC.
