Safe Way To Determine If A Wire Is Live? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 09:19 PM   #1
Safe way to determine if a wire is live?
I pushed up some of the ceiling tiles in my basement and found the end of an electric cable, cleanly cut. Is there a safe (and easy) way to determine if this line is live?
Fortitude is offline   Reply With Quote
Old 10-01-2010, 09:23 PM   #2
Licensed electrician
Rewards Points: 1,876
Although they have limitations, this would be a good spot to use a non-contact voltage detector. Test on a known live circuit.
Old 10-01-2010, 11:37 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I agree with Jim Port with the non concat voltage tester however when you check the conductor to see if that is alive or complety dead just make sure you don't touch the ceiling grid when you do this somecase it will be bonded one way or other if that complety dead then back track where that goes and if complety cut off on both end then you know it is non useable cable.
Merci.
Marc
Old 10-02-2010, 08:16 AM   #4
jlhaslip's Avatar
Rewards Points: 2,872
cut the last inch with a pair of sidecutters. watch for sparks and/or the breaker tripping.
Just kidding, of course...
[edit]
smilies and comment added to indicate this was posted in jest
[/edit]
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-02-2010, 08:41 AM   #5
Just call me Andrew
Rewards Points: 1,020
I don't agree with this at all....get the non-contact voltage tester:
http://www.lowes.com/pd_18400-12704-...act%2Bvoltahge
Andrew
secutanudu is offline   Reply With Quote
Old 10-02-2010, 09:08 AM   #6
Rewards Points: 6,652
I do believe it was meant to be a joke. I personally like taking the wire to my tongue and seeing if there is any voltage going through the line.
Old 10-02-2010, 09:42 AM   #7
Just call me Andrew
I figured it was a joke...but those are the type that could get someone hurt if they don't realize. Not everyone on the forums knows much about this stuff, especially the new people!
Andrew
Old 10-02-2010, 10:52 AM   #8
DISCLAIMER: Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DIYChatroom.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precautions and reference reliable outside sources before attempting any DIY project!
Old 10-02-2010, 11:24 AM   #9
Just call me Andrew
Yes, I realize the disclaimer is there. Still, I see no reason to joke with someone about cutting a live wire when they may not perceive it as a joke.
Andrew
Old 10-02-2010, 12:09 PM   #10
Thanks for the info about the non-contact voltage detector. I'd never heard of that before.
I did recognize the joke answers. :-)
Old 10-02-2010, 12:34 PM   #11
If you can not recognize when a person is joking, then you are taking life way too serious. Yes, there are some things more dangerous in life than others, but when asking questions in a DIY Forum, you pretty much know that you have concerns.
Old 10-02-2010, 02:04 PM   #12
Just call me Andrew
I am all for joking...but do you know how new at electrical work some members are here?
Andrew
Old 10-02-2010, 02:59 PM   #13
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Another option is a volt meter, just touch the ends if they are easy to get to. The wire itself is safe to touch and handle, you just don't want to touch the end. Now if the ends are very close together there's a possibility of a short if you play with it too much, so if you need to move it around to get to, may want to shut the main, then turn it back on to test.
If it's live then turn a breaker off one at a time turning the last one back on, until you find the one that controls it.
Old 10-02-2010, 07:16 PM   #14
Bigplanz's Avatar
Rewards Points: 996
I was tracing a gas line in my basement last year and came across an old piece of BX, just cut off. I thought, "I wonder if this is hot?" I put a pen tester on it and it beeped like a mother. Great, hot cable just cut off and left up in the floor joist, laying on top of HVAC ductwork. I think it was an old circuit that went up to the kitchen which was abandoned when somebody remodeled the kitchen years ago. I carefully stripped and capped the wires and put the whole thing in 4 square electrical box. I have tapped into it for some basement lights and sockets, so I guess I was fortunate to find it. However, ASSUME NOTHING when you are in an old house. You will find some crazy stuff, like, oh, a hot cable cut off and laying on metal ductwork.
Bigplanz is offline   Reply With Quote
Old 10-03-2010, 06:10 PM   #15
Heres something, if you dont have a non touch tester, try this put a regular flouresent bulb upto the romex (not cfl) dont touch the metal ends of bulb to the end of the romex wire. The bulb will glow ever so lightly in a darken room, because the emf in the wire will excite the photons in the gas in the tube.
Kirky is offline   Reply With Quote
How would you determine if the wire running TO the box is 200amp? CoconutPete Electrical 12 04-30-2010 05:59 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
