Safe Wattage To Use In Ceiling Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 02:18 PM   #1
Safe wattage to use in ceiling socket
I have a cattery/ small bathroom in my garage. There is one light socket in the ceiling with no fixture of any kind. I want to put in some kind of bulb to heat the little room as much as possible but don't want to burn the garage down. I have no idea how high the ceiling socket is rated. Any suggestions out there? Any and all help would be greatly appreciated - Thanks!
pamesu is offline   Reply With Quote
Old 01-02-2011, 02:42 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,866
This type of fixture is NOT designed for a heat lamp. DO NOT use one there.
Typically these lamp holders will accept 150A regular lamp, sometimes more.
The Following User Says Thank You to Speedy Petey For This Useful Post:
pamesu (01-02-2011)
Old 01-02-2011, 02:46 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 66
Most of those sockets seem to have a rating of 150w but without knowing for sure I would not put anything more then a 100w bulb. you can probably unscrew the socket from the wiring box and look under it, sometimes the rating is there.
The Following User Says Thank You to Red Squirrel For This Useful Post:
pamesu (01-02-2011)
Old 01-02-2011, 04:15 PM   #4
Rewards Points: 6,652
Porcelain Edison base can normally handle 100 watts, maybe 125. Plastic Edison base can be rated to a max of 100, but normally they only allow for max of 60 watts.
The Following User Says Thank You to gregzoll For This Useful Post:
pamesu (01-02-2011)
Old 01-02-2011, 04:23 PM   #5
Thank you one and all!
THANK YOU ONE AND ALL ~ EXACTLY WHAT I WANTED TO KNOW!
Old 01-02-2011, 05:03 PM   #6
If the wiring is up to par for the ceiling (ie 12/2, 20 amp circuit), you may be able to use a ceiling heater/light combo. If able to pull another circuit for just a ceiling heater/exhaust fan, go with that if just an exhaust fan in the room with light on it.
pamesu (01-02-2011)
Old 01-02-2011, 05:09 PM   #7
Usually a 100a bulb will heat a small room up to some degree
I used to run (2) 100a bulbs in lamps in my small bedroom as a kid to heat my room up
The Following User Says Thank You to Scuba_Dave For This Useful Post:
pamesu (01-02-2011)
Old 01-02-2011, 05:31 PM   #8
Master Electrician
Rewards Points: 3,746
660 watts.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
pamesu (01-02-2011)
Replacing an old porcelain ceiling light socket bellzerr Electrical 2 09-29-2010 04:54 PM
Installing a ceiling fan in a new construction home HEMMY1244 Electrical 4 09-15-2010 08:11 AM
Are old-work ceiling fan boxes safe? secutanudu Electrical 5 05-11-2010 08:06 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 03:52 PM
