Safe To Plug Washer Into Bathroom GFCI Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 09:54 PM   #1
Safe to plug washer into bathroom GFCI outlet?
Hello, in my condo I have one of those combo top/bottom washer/dryers in my bathroom. It has a single 220 plug. I want to get rid of it. My bathroom currently has a 220 outlet (for the combo) and a standard GFCI outlet by the vanity (about 3 feet away).
I want to get a stacked washer and dryer. The dryer can plug into the existing 220. How unsafe would it be to plug the washer into the GFCI? That outlet is obviously meant for razors, hair dryers, etc. since it's not directly under the 220, and I obviously wouldn't run anything while the washer is going.
Is this a major no-no? And is it "up to code"? What does that really mean in this case? Where you plug your washer in is your business, not anyone else's, right? If I sold my condo, I'd be taking my new washer/dryer with me, so why would anyone care?
rajpram is offline   Reply With Quote
Old 03-21-2012, 10:07 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Yes it would work, but technically it's a code violation. The laundry is to have at least one 20A circuit for the purpose of laundry, not to be shared with other areas.
Kyle
Old 03-22-2012, 05:38 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Stacked unit? I would have assumed that the stack would have had just the one outlet....in other words, the washer would tap into the same ckt as the dryer.
Otherwise, what SD515 stated is correct.
Bottom line...if you sell...as long as the bathroom has that dedicated 20a ckt....your good....you could have 20 240Vac ckts in the bathroom if you wanted....(but I would like to see the load center for that one)
Old 03-22-2012, 07:20 AM   #4
Sorry, I misspoke. "Stackable", not "stacked". In other words, two separate units, two separate plugs. What I have is "stacked", what I want to buy is "stackable".
My tiny condo is probably a special case since "laundry area" and "bathroom" are the same? And I just checked ... never noticed this before, but the GFCI does have the 20a notch in it. So as long as I can count my bathroom as my laundry area, I should be good! Even though I'm going to have an ugly washer power cord laying across my vanity :P
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 03:40 PM
gfci in bathroom 700mxzxer Electrical 23 05-04-2011 06:10 PM
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 01:49 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 01:27 PM
Is it a hazard to plug a surge protector into an ungrounded GFI outlet? CuriousWithQuestions Electrical 7 02-01-2008 09:04 PM
