Safe/Legal Placement Of 220V For Stove - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 11:54 AM   #1
Safe/Legal placement of 220V for stove
Please do not take offense, but I bought a "master-electrician's" house, which he and his construction buddies build in 3 days in 1979. OMG! In 25 years of doing reno's I have never seen so many code violations in one house. However, this one has me stumped because I've never had to deal with this.
He put the 220V for the stove in the share wall with the bath. The metal receptacle box is exposed to the underside of the bath, right next to the drains. Common sense tells me that you just don't do that! However, he maintains that this is "legal". Since I can't afford to buy the Canadian/Quebec Electrical Code book, I can't seem to find an answer.
My other problem here, is if I can not leave it there, where can I put it? I can't really move the stove due to the layout of the kitchen, therefore I need to know if it can be surface mounted on the kitchen side of the wall, or can it be flushed mounted in the floor (doesn't seem like a good idea to me if there is a water spill in the kitchen). Note the cable, it's older than the house! He scrounged cable from his work to build his house, I have at least 6 different types of electrical cable in this house, and I have found 10 junction boxes in the basement ceiling with no covers, not attached to the joists and some with 5 and 6 cables.
I have also considered building a water tight enclosure around the box, but I don't know if that would be legal either. Due to all the water damage, this wall, the floor and ceiling has to be torn down and rebuilt, therefore I will have to replace this connection with brand new materials, so I have an opportunity to make if safe/legal!
CanadianEh is offline   Reply With Quote
Old 03-23-2013, 11:57 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't see a problem.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
jbfan (03-23-2013), stickboy1375 (03-24-2013)
Old 03-23-2013, 01:04 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
I know you may think it is wrong, but if the drain leaks, you have other problems to worry about than the electrical boxes under the tub.
jbfan is online now   Reply With Quote
Old 03-23-2013, 02:07 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Tell me why you think this is.
Old 03-23-2013, 02:07 PM   #5
None whatsoever.
Old 03-23-2013, 02:33 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
The only 'potential' thing I see is that it looks like you have SO cord going into that box.
As for location....it's in a box....if water gets up to the level of that box you have bigger issues than the location of the box.
If it was against code, then you wouldn't be seeing outlets under your sink for the disposal and dishwasher.
Old 03-24-2013, 09:13 AM   #7
Thanks for your replies
Yes, the house is full of SO wire, it's dry, brittle and frayed in many places (many places where there is no reason for it to be frayed). As well, most of the cables, including the newer romex, is pinched so tightly by the cable tacks that the sheathing is split or torn.
As for the location, it was under a metal tub, the water was coming in via the stove vent running all over it and on to the floor below. It really wouldn't take much water to create a potential electrical shock to anybody taking a bath.
As for the whether it's against code, that was the point of the question. There is obviously more risk to having an electrical outlet under a metal tub then under a sink, and any power going to a hot tub or jacuzzi has GFI breakers whereas the 220V for the stove does not.
I just need to be sure that when the inspector comes by, he won't object to the location of the outlet.
Thanks,
Cheers, Pat...
Old 03-24-2013, 09:15 AM   #8
k_buz's Avatar
The location is fine. The SO is not.
CanadianEh (03-24-2013), Speedy Petey (03-24-2013)
Old 03-24-2013, 09:25 AM   #9
Part of the plan
Ok, thanks. I fully intend on replacing all the SO cable in the house. All my baseboard heating in on the same type. The cable for the water heater was melting when the tank failed (it was a unit he scrounged from the electrical company when they closed and held in his basement until he needed a replacement, it was dated Dec 1979).
Cheers, Pat...
Help Needed Choosing 220v or 120v Tankless Water Heater and Proper Amperage wonderworm Electrical 13 11-09-2012 08:36 AM
110V from 220v pump circuit DBachman Electrical 10 08-28-2011 12:57 AM
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 02:16 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
