RV Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2014, 03:19 PM   #1
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
RV Wiring
Unreal
clw1963 is offline   Reply With Quote
Old 08-29-2014, 03:48 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
That looks like a mobile home receptacle with the back missing.
Old 08-29-2014, 03:56 PM   #3
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
RV Wiring
5th wheel. So pretty much the same. It's my "spare bedroom" for my place out here in Joshua tree. Starting to take out stuff and paint. This is out of sight out of mind stuff as far as the electric goes. The way it was built.
Old 08-29-2014, 03:58 PM   #4
jbfan's Avatar
Rewards Points: 138
Don't the wires just feed through and the prongs pierce the wires to make the receptacle hot?
Old 08-29-2014, 03:59 PM   #5
Oso954's Avatar
Rewards Points: 414
It is supposed to have a snap on plastic cover on it.
Or are you commenting on the press in wire connection ?
Oso954 is online now   Reply With Quote
Old 08-29-2014, 04:02 PM   #6
jbfan's Avatar
Rewards Points: 138
Both really.
Old 08-29-2014, 04:07 PM   #7
Oso954's Avatar
Rewards Points: 414
It is fairly typical of a lot of RVs today, unless you are looking at a very high end unit.
Old 08-29-2014, 04:18 PM   #8
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Yes, backing plate removed. This was above an AV shelf. Under the shelf the cable exited through a drill hole in the insulated wall board. Protected by wire harness tubing. One went to a 20 amp outlet for the slide out. The other under the forced air.
I'll be putting new outlet in wall next to forced air. Extend the slide out cord (purchase new one). Now a ton of holes to patch. Unbelievable how many screws they put in.
Old 08-29-2014, 04:26 PM   #9
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
I'm not sure. This is how I found it. Maybe better stripped but I can't say I like it.
Old 08-29-2014, 06:15 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
There are millions of these things out there in mobile homes all over the country.
Speedy Petey is online now   Reply With Quote
Old 08-29-2014, 08:38 PM   #11
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
I'm sure. Doesn't mean I have to like 'em.
Not like much will get plugged into most outlets inside there anyway. I'm not necessarily going to change them all. That one was just removed. Not needed. Going to remove the refridge and possibly the stove. The breakers reside below the refridge. I can't wait to figure out how to deal with that.
Old 08-29-2014, 09:02 PM   #12
Nope, no one said you did.
If I encounter them and have to pull them out of the wall they don't go back in. I install a cut-in box and standard device.
At the same time, I wouldn't compel a customer to replace them all unless they felt like spending the money.
Old 08-29-2014, 09:35 PM   #13
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
RV Wiring
Yeah. I pretty much feel the same.
This RV remodel is a new experience for me. Everything has its place and the misses would like things removed and redone.
Like I was saying the load center will need relocated. I'm not too concerned. Just finding the right place for it.... That the wife likes too.
Old 08-30-2014, 07:15 AM   #14
Rewards Points: 1,214
I just replaced a single receptacle with a duplex in the refrigerator compartment on my RV. Ran into the same thing your describing. Cut in a new box and installed a new duplex receptacle. Man that thing sure did look skimpy. Got to make sure the smoke detectors have good batteries and test them every night.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
clw1963 (08-30-2014)
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
