RV Vs Cabin Electric Service - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 01:45 PM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
4/0 urd to feed the meter if its 200 feet or less.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-19-2012, 02:00 PM   #17
rrolleston's Avatar
250 urd would help in your situation since you have a long run then you have to go to the cabin with 4 wire after that. You figure 250 feet between their pole and your meter is 250 feet you will probably have 300+ feet when you go up their pole about 10 with conduit and leave 30 feet for them to make their connection and make the connection in your meter.
Old 03-19-2012, 02:20 PM   #18
I'm sorry, my knowledge of this subject is very limited. We're putting in new permanent electrical service, the elec co will set the poles and place the meter loop on the pole. We have to have everything else ready, from the bottom of the meter loop. We'll be trenching 205 ft where we will be putting a Panel (or disconnect???) I've uploaded a similar picture. Then from there we'll be running a line to the cabin (which doesn't exist yet) and a line to an RV box too. I uploaded the recommended wire specifications. We were told to use the 4/0 triplex but then the elec co said I need Aluminum phase 4/0 and neutral 2/0 (no triplex). This sounds like one single aluminum wire and one neutral wire. I'm confused. I need to hire someone to do this, but haven't been sucessful since it's 3 hours from my home. I want to make sure I get the right wire. Thanks.
RV vs cabin electric service-2012-03-19_11-34-59_143.jpg   RV vs cabin electric service-copy.jpg
trekketoo is offline   Reply With Quote
Old 03-19-2012, 02:27 PM   #19
rrolleston's Avatar
Will they allow your disconnect to be 200 feet from the meter? Are you sure they will install and provide the meter? For underground you will need URD cable.
Old 03-19-2012, 02:39 PM   #20
I do need to make sure they will. Is the picture I posted a disconnect box, is that the same as a panel with feed through lugs? The one above is about 60 ft from the meter loop. That set up is what most are doing and they are all varying degrees of distance. I'm not sure if ours is the farthest or not. Maybe I'm wrong on the type of box that is too. If that makes a difference. Once we trench and have it ready then the electric co will hook up the power on each end.
Looking at the info I just uploaded they show the disconnect near the meter box at the pole. So I don't know. but all the lots are set up at a distance from the pole.
Old 03-19-2012, 02:47 PM   #21
rrolleston's Avatar
This is a diagram showing an underground service install where there is no building yet.
The Following User Says Thank You to rrolleston For This Useful Post:
trekketoo (03-19-2012)
Old 03-19-2012, 02:51 PM   #22
rrolleston's Avatar
If you install the meter and disconnect at the pole you will have to run four wire to your cabin. Best way would be to run 3 wire URD to a meter pedestal where the cabin will be built and use a meter main unit like kbsparky posted.
Old 03-19-2012, 02:54 PM   #23
My husband and I have not met the elec co engineer, our local contact there has done that. I think we need to meet him to make sure we have everything in order. Didn't realize getting electricity would be so complicated. Would glady pay Black River Electric to do the electrical work and we can do the trenching.
Old 03-19-2012, 03:04 PM   #24
rrolleston's Avatar
I would suggest meeting at your property with a reputable electrician or electrical contractor and the POCO engineer. I like doing it that way because everyone involved is there and can ask questions and decide the best way to do it. I did an underground electrical service and if the landowner ever gets the easement signed so I can make the final connections I will grab some pictures.
Tags
camper , electric , trench
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 07:55 PM
"Moving" service entrance WillK Electrical 4 09-29-2010 01:04 PM
Running underground electric service and am unsure of what wire is needed. Help stquality Electrical 10 08-15-2010 10:14 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
electric service in garage kelr Electrical 2 03-26-2005 08:38 PM
