RV Electrical Shore Power - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-24-2007, 10:32 AM   #16
re-thinking
Originally Posted by HouseHelper View Post
Actually, the three wire dryer circuits are two hots and a neutral. The exception was that the dryer chassis was allowed to be grounded through the neutral as long as the circuit originated at the service panel and not from a subpanel. The wiring was to be three insulated wires or SE type cable.
I did some research into dryer receptacles and read an article that indicated that yes, the older homes w/3 wire recepts. did use the dryer chassis as a ground. The articles emphasized the importance of disconnecting that ground if converting to a 4-wire plug.
I'm thinking this is over my head and I should get a licensed electrician if I want to change out a 2P breaker to a single phase, re-wire a receptacle, etc. I also want it to be easy to re-convert if/when I sell the house. Do any of you know if this would be against any codes? I do have the NEC here in my office if you could refer me to roughly the right section.
Thanks.
DaRose is offline   Reply With Quote
Electrical power goes off randomly Rompegato Electrical 7 05-30-2007 09:50 PM
Furnace Electrical Supply.... caseywa HVAC 2 12-28-2006 10:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
integrating electrical surge protector into wall? aznboi04k Electrical 3 11-23-2005 10:01 AM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
