Running Wires Within Kitchen Island - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2014, 07:05 PM   #1
Rewards Points: 36
Exclamation
Can the wires running inside a kitchen island cabinets' be hanged bare with cable clamps only, or does it have to be encased in metal conduit?
If metal conduit, can flexible conduit be used, and if yes, does it have to be Armored Cable (wiring pre-installed within flexible metal conduit) or can standard Romex be pulled through typical off-the-shelf empty flexible conduit?
I read somewhere that wires need to be protected with conduit to prevent being accidentally pulled from by drawers and stuff on shelves, and flexible conduit seems easier to install than EMT.
Augster is offline   Reply With Quote
Old 08-21-2014, 07:50 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,104
I prefer FMC. Romex should be protected.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Augster (08-21-2014)
Old 08-21-2014, 08:27 PM   #3
Licensed electrician
Rewards Points: 3,382
I use Panduit plastic split duct to keep the cables out of the way and provide bump protection.
Old 08-21-2014, 08:58 PM   #4
Rewards Points: 353
I run mc most of time
Cletis is offline   Reply With Quote
Old 08-21-2014, 09:25 PM   #5
Rewards Points: 2,766
Originally Posted by Jim Port View Post
bump protection.
I like...
I think that should be a new term in the NEC.
ritelec is offline   Reply With Quote
Old 08-21-2014, 09:45 PM   #6
Rewards Points: 36
I see how that would provide bump protection, but how would it fair against getting snagged?
Old 08-21-2014, 09:50 PM   #7
Rewards Points: 36
I also prefer flexible metal conduit.
Since they will connect to metal "old work" boxes (those seem the easiest to mount onto the island sides), I assume the boxes will need to be grounded via pigtail to the bare ground wire using "green" grounding screws.
Old 08-22-2014, 07:04 AM   #8
I run the cable in the corner where the chances to get snagged are almost zero.
HouseHelper (08-22-2014)
Old 08-22-2014, 07:30 AM   #9
Snagg protection?
Old 08-22-2014, 07:50 AM   #10
Yes, snag and bump protection since none of these meet the NEC requirements against physical damage. I don't see under a sink or in a cabinet as needing rigid or Schedule 80.
Augster (08-24-2014)
Question about running wires justin_bliar Electrical 5 02-01-2012 10:37 AM
tile around kitchen island and around kick plates cmlcsu Flooring 4 01-08-2012 10:35 PM
kitchen island outlet wiring problem colarama Electrical 3 09-22-2011 05:51 AM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 09:12 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
