Running Wires For Wall Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 03:36 PM   #1
Rewards Points: 87
running wires for wall heater
Ive got an electric wall heater that's 120v and pulls 12.5 amps. What's the easiest way to wire it up? Can I run it off of an existing breaker or can I tie in to other wires near by?
Roundeye is offline   Reply With Quote
Old 09-17-2011, 03:43 PM   #2
Electrician
Rewards Points: 794
With that type of load you will need a dedicated circuit. In Canada you could get away with #14 wire and a 20A breaker, with that said I would still run #12 and a 20A breaker if it was me.
darren is offline   Reply With Quote
Old 09-17-2011, 03:57 PM   #3
Licensed electrician
Rewards Points: 1,608
You would need a dedicated circuit under the NEC. You cannot add this to a circuit that would also have cord and plug connected loads since it is over 1/2 of the circuit rating even for a 20 amp circuit.
Size of baseboard heater wires humberguy Electrical 1 08-19-2011 10:26 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Running wires g60vwr Electrical 9 06-06-2010 06:15 AM
Heater help & Phase? Captflx Electrical 3 11-19-2009 10:06 PM
running wires in a vaulted ceiling Did it myself Electrical 2 01-17-2009 07:37 AM
