Running Wires For NEW Outlets In Plaster And Lathe - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 08:39 AM   #16
I ask the impossible!
Rewards Points: 704
Originally Posted by philS View Post
Scuba , OP, others - Don;t forget about our old friend the the angle grider with a metal blade. The high speed and circular motion (not reciprocating) cuts way down on the vibration, and tends not to bring the whole wall down on top of you. And the discs are cheap. Just keep some water handy and make sure you're nowhere near your smokie - ie you WILL see smoke. Good luck.
I hate lathe and plaster! Doesn't take much of an excuse before I hire HS and college kids to rip it out completely (they love to get dirty). Then I do what needs to be done, then rock it.
And yes, my Fein tool gets used almost every day! -- Phil
I'd point out, though, that this also makes a lot more dust. And where there's L&P there's also a probability of lead hazards.
I've put old work boxes into L&P in my kitchen, but it was also behind 2 layers of sheetrock and I didn't care what happenned to the plaster.
WillK is offline   Reply With Quote
Old 01-05-2011, 12:27 PM   #17
Rewards Points: 1,538
It is possible you may have to cut additional holes in the wall (through the lath too) to assist in fishing the wires through.
Patch them using ordinary modern drywall patching techniques.
Old 01-05-2011, 01:46 PM   #18
RST
DIY Homeowner
Rewards Points: 150
Originally Posted by Jim Port View Post
You may want to check out the new SmartBox style old work box that screws into the side of the stud and provides a much stronger mounting and does not flex the plaster when using the receptacle.
With some digging around I found such a box at a local big box store! Not the original, a version made by Arlington.
RST is offline   Reply With Quote
Old 01-05-2011, 05:24 PM   #19
WaldenL's Avatar
Rewards Points: 268
I've found the dremel multimax to be great for cutting into P&L, none of that vibration caused by sawzalls. As for the box, if you're not comfortable don't do it, but if you're willing to learn it's not hard to wire something into the box.
WaldenL is offline   Reply With Quote
Old 01-06-2011, 03:38 PM   #20
Just a word of warning. If you have rock plaster like I do, your blades will last about half a box hole before there are no teeth left. Using a Fein type tool will get VERY expensive quickly (blades). I finally started hand cutting mine using a hacksaw blade in a single ended holder after drilling a starter hole.
Mike in Arkansas is offline   Reply With Quote
Stud Finding on Plaster and Lathe? Scotsman General DIY Discussions 9 12-06-2009 04:11 AM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 02:20 PM
Plaster walls and Lathe Keith in Connecticut Remodeling 5 01-03-2008 07:36 PM
How strong is plaster & lathe Keith in Connecticut General DIY Discussions 6 08-24-2007 10:46 AM
replacing lathe and plaster eager2lern Building & Construction 2 12-04-2006 12:52 PM
