Running Wires In New Construction - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 12:01 PM   #1
Rewards Points: 93
Running Wires in new construction
If when running wires for new construction to maintain the 1 1/4" space yuo obvisously can't staple them next to each other, and the staples can only take 1 cable? Is it good practice to come in through the top of the box for an outlet and when running out to the next, go through the bottom over to the bottom of the next and then out through the top? and continue this around to all outlets? Also any recommendations for box sizes? 2X4 walls? Should I get the largest? except for exterior walls where you may want to get insulation behind?
bfan781 is offline   Reply With Quote
Old 03-12-2010, 12:17 PM   #2
Master Electrician
Rewards Points: 3,746
I would recommend 22 or 23 cubic inch boxes everywhere. The savings is little for smaller sizes. Depending upon the listing of the staples you use, more than one cable can go uder a staple.
brric is offline   Reply With Quote
Old 03-12-2010, 12:26 PM   #3
Rewards Points: 93
Great thanks. I had 1/2 in staples left over. Do you ever go top to bottom like I mentioned or is it better to get the larger staples, or is it all the same. Lastlydo I have to be concerned wit the bends coming out of the boxes going through the holes to run horizontal? Just fan them out a little?
Old 03-12-2010, 12:36 PM   #4
Master Electrician
You can do it that way but your holes will have to be drilled much lower. Drilling at a little under waist high makes for much easier wire pulling. Whether you go over or below just don't drill too close to the box. Not only wil it be harder to get the cable into the box it will be very difficult to staple them.
Old 03-12-2010, 01:05 PM   #5
Rewards Points: 93
So I am better off just drilling above and getting staples that can hold more than one wire. Thant way I can leave space to turn and get down into the box.
Old 03-12-2010, 10:42 PM   #6
Rewards Points: 93
What size staples should I use to fasten two wires together?
Old 03-13-2010, 12:50 AM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
1/2"is all i carry onmy trucks
plummen is offline   Reply With Quote
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 07:18 PM
I installed a new thermostat and the fan will not stop running. The wires are correct TSA0282 HVAC 2 03-02-2009 04:20 PM
running wires in a conduit analogmusicman Electrical 50 07-13-2008 09:49 AM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
