Old 07-20-2011, 08:35 AM   #1
running wires / NEC question
Hi -
My city uses NEC 2008. I am in the process of finishing the basement in a relatively new construction home. The exterior walls are 2x2 with insulation between the studs and the cement wall.
Before installing all of the wiring/receptacles/switches - does code allow wiring to be run behind the studs (between studs and insulation) since they are 2x2 or do we still have to drill through them and run the wires through like in a 2x4 wall?
duhtroll is offline   Reply With Quote
Old 07-20-2011, 08:58 AM   #2
Originally Posted by duhtroll View Post
Hi -
Never seen 2x2 studs used before. You have to have a minimum distance for mechanical protection (not sure on the distance for NEC). If you ran the wires behind the studs you would still have to find some way of supporting the cable.
CheapCharlie is offline   Reply With Quote
Old 07-20-2011, 09:31 AM   #3
Electrical Contractor
Keep wiring 1.25" from the front of the 2x2
hpp58 is offline   Reply With Quote
Old 07-20-2011, 09:42 AM   #4
Licensed electrician
The cables would also need to be 1 1/4" from the sides of the 2x's.
Old 07-20-2011, 10:34 AM   #5
I ask the impossible!
Really the 2x2's would be more appropriately referred to as furring strips rather than studs I believe, but you might consider using conduit and then you have your mechanical protection and don't have to worry about making a half inch hole in the last quarter inch of your board.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 07-20-2011, 01:29 PM   #6
Lic Electrical Inspector
electures's Avatar
Is there a gap between the studs and the block wall? If there is you can run the cable behind the studs.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 07-20-2011, 04:22 PM   #7
There is room behind the 2x2 strips (it is basically a nailing surface) and in front of the insulation so we will be running the wiring behind the studs, securing every 48" and that will allow 1.75" plus the 0.75" for the drywall - should be fine.
Running wires alongside or through ductwork j_sun Electrical 1 07-13-2011 12:11 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Dumb question, how do you twist your wires together? Piedmont Electrical 62 04-13-2010 03:50 AM
Basic cable running question epeterson777 Electrical 14 02-07-2009 07:33 AM
running wires in a conduit analogmusicman Electrical 50 07-13-2008 09:49 AM
