Originally Posted by Jim Port
If the chase already exists it is easy to drop a weighted string down into the basement and pull cables into the attic.
I would stuff the top and bottom to stop air movement and to limit the chimney effect in the event of a fire.
Thank you. Is this in lieu of running a conduit for electrical?
Just make a hole in the metal sheeting on the top (Attic) and bottom (Laundry) of the chase everytime a new wire is needed, run the wire, and then seal around the hole with fireretaring caulk?
For low-voltage wires, would you use a similar approach or use a conduit?
