Running Wires Across Bottom Of Joists - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 12:30 PM   #1
WaldenL's Avatar
Rewards Points: 268
Question
Running wires across bottom of joists
OK, I'm beginning to be sorry I started reading up on the code, I never knew how bad my house was! Since it's existing work I assume I don't have to pull it out, but I've got probably a dozen different wires running like shown below. As I'm reading it, I cannot run wires smaller than 8AWG across the bottom of joists. I assume "smaller than" refers to physical size, not a lower AWG number. So, I cannot run 14AWG across the bottom of joists. Right?
Other than drilling (a lot) of holes in the joists what are my options here? I'm less worried about what's there already, it's there already, but if I run more, I assume I can't do the same since it's not up to code, but drilling all those holes seems silly too.
WaldenL is offline   Reply With Quote
Old 01-25-2009, 12:35 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I may stand corrected but I thought that was just in unfinished basements.
wirenut1110 is offline   Reply With Quote
Old 01-25-2009, 12:53 PM   #3
WaldenL's Avatar
Rewards Points: 268
This is in an unfinished basement. The joists in the pic are the bottom of the first floor. The pipe down the middle is a gas pipe, and the insulated pipe at the top of the pic is part of the heating system.
Old 01-25-2009, 12:57 PM   #4
joed's Avatar
Rewards Points: 11,500
It is lower AWG than 8 guage. Your option is to place a running board beside the wires to protect them. I think the problem is preventing people using the wires as a clothes line.
Old 01-25-2009, 12:59 PM   #5
Rewards Points: 510
Oh, I thought it was crawl space. In that case, if you're trying to "finish" the basement, I'm thinking acoustic ceiling.
Old 01-25-2009, 01:16 PM   #6
WaldenL's Avatar
Rewards Points: 268
OK, not to be silly, "It is lower AWG than 8 guage." means a lower number (6) or a smaller size (14). IOW, it's ok to run 6AWG across the joists, but it's not ok to run 14AWG, right?
Old 01-25-2009, 01:36 PM   #7
You are allowed to run a 1x board perpendicular to the joists and run them on the face of that.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-25-2009, 03:28 PM   #8
Yes, lower gauge (14) not lower number
I used some old trim to run across the 2x joists, the nailed my wire to that as suggested
Old 01-25-2009, 04:00 PM   #9
kbsparky's Avatar
Just run them along the sill plate, and fasten to that. No running boards required.
garage ceiling joists josh123 Carpentry 6 07-15-2009 12:07 AM
running wires in a vaulted ceiling Did it myself Electrical 2 01-17-2009 08:37 AM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 09:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
