Running Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 07:55 AM   #1
Running wires
Hi everyone just a quick question.
I installed some hi-hats and Im running the wires light to light.
The beams go N-S and the Wiring has to go E-W. Should I staple the wires to the tops of the beams or drill holes through?
I usually would staple to the beams to make the wires out of the way, but there are none.
Thanks in advance
g60vwr is offline   Reply With Quote
Old 06-04-2010, 08:28 AM   #2
Licensed electrician
Rewards Points: 1,892
Are you really dealing with beams or are they trusses or joists? It makes a difference. Trusses do not get drilled, beams you might be able to drill, but would need to check an engineering sheet. Joists can be drilled with some limitations or hole locations and sizes.
Old 06-04-2010, 08:33 AM   #3
Im sorry, im not sure. It does not look like a truss system, its older construction of 2x6. They look like regular rafters to me.
Old 06-04-2010, 08:36 AM   #4
If these are 2x6's you can drill to run your wiring. Drill your holes halfway between the top and bottom of the wood. Be sure to check for wiring, plumbing and duct work before drilling.
g60vwr (06-04-2010)
Old 06-04-2010, 08:48 AM   #5
Thanks, Will do!
Old 06-04-2010, 08:48 PM   #6
Just curious if you HAVE to drill holes in this situation of if stapling to the bottom of the rafters is acceptable in an unoccupied attic space.
Mike in Arkansas is offline   Reply With Quote
Old 06-04-2010, 09:28 PM   #7
Are you drilling thru rafters or joists ?
I would not drill thru 2x6 rafters myself...unless a very short span
On an older house a 2x6 roof rafter may already be beyond todays code listing for span
Old 06-05-2010, 06:45 AM   #8
Well, I dont HAVE to drill at all. I want to sometime in the future (maybe) put a second floor on the house and was trying to make it as "correct" as I could
Old 06-05-2010, 04:04 PM   #9
Rewards Points: 320
Is there strapping underneath the joists? I had the same situation in my ranch house and was able to run the cable under the joists so that we could possibly add a second floor someday without ripping out all of my new wiring.
teamo is offline   Reply With Quote
Old 06-06-2010, 06:15 AM   #10
No, No such luck. Its just the joists and some drywall. I think I may just tack to the tops of the joists, seems like the easy way out, but Im willing to bet if I ever do a second floor Im going to have to rip the joists out anyhow. I have to get it done and have to make my decision pronto.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Wires running into receptacle and switch boxes Abs777 Electrical 6 04-28-2010 12:50 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 06:18 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
