Running A Wire Through The Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 07:52 AM   #1
Rewards Points: 356
Running a wire through the wall
Is there an acceptable way to run a power cord into an equipment closet located directly behind the tv mounted on a wall. With the newest LCDs it is nearly impossible to mount the unit on a wall with the available close mounts with out sharply bending the power cord even when using a recessed outlet. It also does not allow powering from a source (receiver) that senses the tv is on or off.
There is an existing pass through for component cables and other HDMI cables and a recessed outlet that works fine with the old tv. The new tv mounts nearly flush with the wall causing a problem with the power cord. Any ideas will be appreciated.
Rege
RegeSullivan is offline   Reply With Quote
Old 09-27-2009, 08:28 AM   #2
Rewards Points: 109
There are recessed mounts available
BimmerRacer is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
wire sizing for wall heater? gerhops Electrical 22 09-21-2008 09:59 PM
Bury Low Voltage Wire in Wall? Tool Junkie Electrical 3 06-16-2008 07:38 AM
Running wire ADKstorm Electrical 1 09-27-2007 11:43 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
