Old 07-07-2009, 12:48 PM   #1
running wire through open walls?
I am working on a remodel project. I have open walls and ceiling, all wood construction, to run wire through. My project will be inspected in the end so with code in mind, can more than one cable (nm) be pulled through a drilled hole? If so, is there a max per size of hole and/or size of wire? I'm running 14/2, 14/3 and 12/2
Thanks in advance
TReally is offline   Reply With Quote
Old 07-07-2009, 08:31 PM   #2
Yes
Loaded question.^
Generally electricians here use 1 1/8" auger bits . This almost leaves the required 1 1/4" setback on a 2x4 stud.
220/221 is offline   Reply With Quote
Old 07-07-2009, 08:48 PM   #3
Code05's Avatar
I use a 7/8 or 1" spade/ auger bit and only run 2 cables per hole, code probably specifies something for hole size, but I am not sure and am too lazy too to look it up right now. As 220/221 said there is a min. of 1 1/4" of setback from both faces of the stud so if exceed this or use a larger drill bit you need nail plates.
Code05 is offline   Reply With Quote
Old 07-08-2009, 11:42 AM   #4
J. V.'s Avatar
This is where planning is helpful. If you plan, you should have very little need for more than two wires in any hole at one time.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 11:27 AM
Advice/Tips on running down walls boxer1-2 Electrical 2 10-04-2005 12:38 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
