Running Wire Through Door Framing & Shoplight Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 05:06 AM   #1
Just call me Andrew
Rewards Points: 1,020
Running wire through door framing & shoplight question
I have an unfinished exterior wall in my garage. I'd like to get wire from one side of the door to the other. Is it safe to drill through all the cripple studs above the door to run some 12/2 or would that make the wall unstable ? See the red line in the picture below.
If not, can I run romex on the inside of the studs? I know this would get in the way of drywall, but I have no plans to ever finish this wall. actually, I'd prefer to do this than put holes through all the studs.
I am doing this to get wiring for a 4' 2-bulb light over my workbench. What type of lighting is recommended over a workbench? The only one I could find that says it would work in cold weather (unfinished garage) was a T-8. I read that I'd want a "daylight" style bulb for a work bench, but I couldn't find one that bright in T-8.
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 02-14-2010, 06:13 AM   #2
Rewards Points: 1,016
Here is a link to an article that has pictures of running wire in an unfinshed garage. As you will see, basically the installation minimizes any possible damage, so nothing can be hung from a wire, etc.
http://www.rd.com/advice-and-know-ho...460.html#slide
Old 02-14-2010, 11:33 AM   #3
jlhaslip's Avatar
Rewards Points: 2,726
the edge of the hole you drill can be no closer to the face of the framing than 1 1/4 inch, so a 3/4 inch hole centred in the framing member above the door should be okay.
if you are worried, there are plate available that you mount onto the studs to protect the wires from stray nails/screws, but if the hole is far enough back (1 1/4") then the plates are not required.
Structurally, these holes won't matter.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-14-2010, 10:55 PM   #4
Just call me Andrew
Thanks!
Andrew
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
running wire underground for outdoor outlet ponch37300 Electrical 11 06-26-2009 09:41 AM
Running speaker wire parallel to electrical wire spyguy Electrical 3 02-21-2007 02:10 PM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 09:14 PM
running wire questions jude Electrical 4 12-01-2006 12:41 AM
