Running Wire Through Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 01:53 PM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
Running wire through conduit
I am planning on installing a Leviton pull switch lamp holder and an outlet in the attic. I will draw power from a box already there in the attic.
Planned wiring
The Runs marked A and B will be some sort of flex metal conduit, perhaps 1/2".
The outlet and lamp will be mounted on metal box.
What sort of conduit for runs A & B do I use to be in compliance?
I am thinking, Southwire 1/2 in. X 100 ft.Flex Alum Conduit.
What sort of wire do I run in the conduit, romex?
Or, option three is to use Southwire Armorlite 25 ft. 14/2-Gauge Solid Metal-Clad Cable.
picflight is offline   Reply With Quote
Old 08-27-2011, 02:10 PM   #2
Code05's Avatar
Rewards Points: 1,104
Option 4: Use NM and only sleeve it where subject to damage.
Code05 is offline   Reply With Quote
Old 08-27-2011, 02:30 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,974
Yep.....no need for conduit if not exposed to potential damage.
You might be thinking wiring in a garage....you can't have exposed Romex...wire has to be in conduit or behind drywall.
Attic is not considered to be occupied on a normal basis.
But if your concerned that you or someone else to accidently damage the wire...then 1/2" armored flex is fine.
Old 08-27-2011, 02:45 PM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
Yes, that is exactly what I was thinking, if it can be touched then it has to be covered.
I might not have to do it in the attic but I would like to.
So romex in flex is code?
Old 08-27-2011, 02:57 PM   #5
Code05's Avatar
Romex in flex is legal.
If it is just sleeves, fill does not count.
If it is a complete system, fill counts.
Old 08-27-2011, 03:10 PM   #6
JOATMON
ddawg16's Avatar
As Code5 says, you can put Romex in flex....as far as I know, the NEC does not prevent it in regular conduit either (b!tch to pull though).
I would double check with your local building office....good chance you have the same rules I do...my building inspector will not allow Romex in conduit...and I believe they consider flex to be conduit as well.
Me personally? I use conduit and THHN up in the attic....that wire is a lot easier to work with.
Old 08-27-2011, 03:14 PM   #7
Code05's Avatar
ddawg, everyone considers Flexible Metallic Conduit as conduit.
Local rule no romex in conduit???
Old 08-27-2011, 03:20 PM   #8
Busy DIYer
picflight's Avatar
Rewards Points: 150
What does fill mean?
Old 08-27-2011, 03:23 PM   #9
Code05's Avatar
It means how many wires you can fill a conduit with.
Old 08-27-2011, 03:26 PM   #10
Code05's Avatar
If you really want to use a metal protected cable. MC would be easier than flex and romex.
Old 08-27-2011, 03:33 PM   #11
Busy DIYer
picflight's Avatar
Rewards Points: 150
Thanks code.
If I use THHN 12 gauge, I will have to buy 2 rolls, black and white? And separate ground?
How is MC different than flex?
Old 08-27-2011, 03:48 PM   #12
Code05's Avatar
Thanks code.
MC is a cable with the wires inside.
Flex is conduit, you pull the wires inside.
Yes, black,white and green or bare.
Old 08-27-2011, 04:10 PM   #13
JOATMON
ddawg16's Avatar
Maybe some clarification is in order....
You can get 3 kinds of flex....
Metal Flex that already has 3 wires in it....
Metal Flex with no wires....you run your own
And Plastic Flex (some call it Seal Tight) with no wires in it...you run your own.
You typically see Plastic flex used in wet locations....like getting power to a motor that is in a wash down/splash down location
Old 08-27-2011, 04:20 PM   #14
Code05's Avatar
Actually there is:
Armor Clad cable
Metal Clad cable
Flexible Metal Conduit
Liquidtight Flexible Non Metal Conduit
Liquidtight Flexible Metal Conduit
Electrical Non metal Tubing
The Following User Says Thank You to Code05 For This Useful Post:
brric (08-27-2011)
Old 08-27-2011, 06:52 PM   #15
Busy DIYer
picflight's Avatar
Rewards Points: 150
I got all the parts this afternoon, it was 105F in San Fernando valley when I went out.
I decided to go with option 3, mc.
This sub-project is part of an attic fan replacement.
Will post pictures of finished wiring.
Tags
conduit , romex run
running wire for 50A subpanel in a detached shed amakarevic Electrical 10 03-17-2011 05:04 PM
Question about running wire to storage building chris c Electrical 7 01-28-2011 02:33 PM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 11:41 AM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 07:43 PM
Conduit for #6 wire joey b Electrical 13 11-22-2008 12:13 PM
