Running Wire Through A Cold Air Return? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-12-2008, 08:13 PM   #31
electrician
Originally Posted by Lansing View Post
My Uncle John was never a monkey's uncle but your intitled to your opinion on him though I bet you would never say that to his face...But what about my answer?? was it right or wrong ??or do you even know ??
Yes I do know, you're wrong...................... and so is your uncle
Silk is offline   Reply With Quote
Old 02-25-2010, 09:58 PM   #32
Plenum Rated Cable?
The OP originally asked about running Romex through a joist cavity being used as a cold air return. I'm trying to accomplish a similar task. Someone else said that it could be done if it is in a conduit or MC type cable.
Is this accurate? Is there any electrical cable rated for plenum use? (BX / MC, etc...)?
skirack is offline   Reply With Quote
Old 02-26-2010, 02:44 AM   #33
Rewards Points: 866
But nm in the space enclosed by joists and the ceiling of one story and the floor of the next can be used as a raceway for nm, can it not, as long as the space isn't being used for routing air for heating or cooling, yes? I did that for cable to a ceiling fan and light, while stapling the cable half way up the side of a joist.
Klawman is offline   Reply With Quote
Old 02-26-2010, 09:32 AM   #34
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If it were me and I needed to cross a cavity that is being used as a duct or plenum (trying to avoid that argument again), I would use a piece of EMT large enough to comfortably put the NM through it and seal the ends of the EMT to the studs/joists with a fire caulk. While this is not necessary, I believe it provides for the best installation as the NM, if exposed to excessive heat, will not gas off toxic fumes into an air handling space and where the stud/joist is penetrated, there will be no air leakage.
in the code section concerning duct and plenums, MI and MC (only that type with a continuous smooth or corrugated outer sheath without a non-metallic outer layer (in other words, not the typical MC with the spiral wrap metal sheath as well as any MC that has an outer non-metallic sheath) is allowed as well as solid metal conduits (FMC has very limited and specific uses allowed but not as a general wiring method.)
in "other spaces used for environmental air", basically, the material needs to be listed for use in a plenum air space.
If that doesn't make sense. let me know. I realize it is confusing as written but trying to avoid excessive verbiage.
correct. the problem comes in when the cavity is being used as an air transfer space that could conceivably cause toxic gases to be spread throughout the building should the plastic sheath be exposed to excessive heat.
Old 02-26-2010, 10:09 AM   #35
Wow! Now I know why I joined this chatroom. Gret stuff people.
Maximo is offline   Reply With Quote
Old 02-27-2010, 01:05 PM   #36
Rewards Points: 160
Its bad business to do that...The answer is no... My Uncle a master electican said a good electican wouldn't do that anyway...
My uncle is a truck driver and he says its okay to do it.
Welcome to the forum.
Old 02-27-2010, 03:08 PM   #37
nap
You talking to me?
nap's Avatar
all my uncles are deceased and they didn't have anything to say about the subject.
did that cross the line?
Old 02-28-2010, 10:57 AM   #38
Rewards Points: 160
No.
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 08:42 AM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 07:52 AM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 10:54 PM
