Running Wire Through Cabinets Or Jack Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 04:32 PM   #1
Rewards Points: 398
Running wire through cabinets or jack studs
I'm planning on extending my kitchen a foot and a half. I will be narrowing an entry way by 1 1/2 feet on both sides. I would like to move a light switch closer to the new opening. The only way to run the wire would be through cabinets (my last GC said he has seen this done before) or by drilling a hole through 2 jacks and a king stud. Can jack studs/king studs be drilled?
Malcolm is offline   Reply With Quote
Old 09-19-2013, 04:35 PM   #2
what type of wire?
itsnotrequired is offline   Reply With Quote
Old 09-19-2013, 06:52 PM   #3
Licensed electrician
Rewards Points: 1,026
They can be drilled.
stickboy1375 (09-19-2013)
Old 09-19-2013, 09:42 PM   #4
Rewards Points: 398
[QUOTE=itsnotrequired;1243841]what type of wire?[/Q]
14/2 romex wire
Old 09-19-2013, 09:47 PM   #5
Rewards Points: 398
Now that I think about it, I might have to add a junction box somewhere. Can I add a junction box inside of a covered aluminum soffit. It would be attached to the top plate. It wouldn't be accessible unless I removed the soffit. My other options would be to cut in a junction box on the siding with a blank cover or cut one in inside the cabinet.
Can wires be run in cabinets behind the drawers? Would they need to be in conduit?
Splice or replace entire wire? Septic Pump bsmith6356 Electrical 5 03-18-2013 07:44 PM
Adding phone jack simbey1982 Electrical 22 01-17-2012 05:40 PM
Running wire thru studs spring3100 Electrical 1 12-06-2011 06:29 AM
Running wire to rewire non-grounded cicuits stencil Electrical 8 10-28-2011 07:27 PM
Hanging Cabinets Without Studs jage Carpentry 6 10-12-2011 09:01 PM
