Running Wire For Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 06:35 PM   #1
rek
running wire for subpanel
I'm planning on putting a 60A subpanel in my detached garage there are a few points that I'd like clarification on before I do the work and have it inspected.
I need to make a 50' run from the main panel through the basement, the shortest route would have me going underneath (with conduit) or through a cold air return to the furnace. The cold air return is one of those types that literally uses the space between the floor joists as the return. Would it be allowed by code to go through the cold air return? I really don't want conduit below the floor joists as I may want to finish the basement ceiling in a few years.
Where the feed line goes through the exterior wall does the code specify how high above ground level this must occur? I'll need a small junction box on the exterior to switch to a cable that I can run underground in conduit to the garage.
Thanks.
rek is offline   Reply With Quote
Old 09-22-2010, 07:03 PM   #2
joed's Avatar
Rewards Points: 13,718
You can cross the cold air return but you can't run parallel inside the return.
Old 09-22-2010, 09:59 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by joed View Post
You can cross the cold air return but you can run parallel inside the return.
Joed.,
I hope you did not make a typo on this one It should say Can't
Merci.
Marc
Old 09-22-2010, 10:09 PM   #4
joed's Avatar
Originally Posted by frenchelectrican View Post
Joed.,
Merci.
Marc
Typo corrected in original post.
The Following User Says Thank You to joed For This Useful Post:
frenchelectrican (09-22-2010)
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
running 2 circuits off 14/3 wire 2mshepherd Electrical 3 06-15-2010 12:16 AM
Running Under ground wire Robbro137 Electrical 1 08-21-2009 05:11 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
